Quick Search for Fulfillment Workbench
Good day all!
I was wondering if anyone has successfully added a Quick Search to the Fulfillment Workbench. So far, I cannot figure out what my Return column, and Context Key needs to be in order to get a Quick Search to appear in the Quick Search tab list.
Thanks to anyone who’s gone down this road before.
The more I look into this, the more I think it’s not possible. No key fields in Fulfillment Workbench to hang off of…
PartDtl.SysRowID
You search by the SysRowID?
Check out:
That’s the key field you need for the fulfillment workbench search. If you are using a BAQ search or a BAQ in a quick search, you need that field to be returned. In a BAQ that is being used for the BAQ search, set it up in the BAQ search tab.
2022-04-19 08_24_53-Business Activity Query Designer
Phil coming in clutch 5 years later. That’s dedication.
Thank you Phil, cause I’m sure this will save a lot of people.
