Quick Search Parameter: Workflow Group
Thanks very much Tanya!
After further investigation I think creating another search is going to be the only remedy to this issue.
--- In vantage@yahoogroups.com, Tanya Denison <tdenison@...> wrote:
> What I've found is that if you do an outer join on your QS BAQ, it will
> bring back all records. If you want a QS based on a field that is not
> always populated, you should create a second search.
> *Tanya Denison* | IT Manager | NRS, Inc.
> *2009 S. Main Street, Moscow, ID 83843*
> *tdenison@... *|* www.nrsweb.com*
> *c: 208.301.0599* | *p: 208.883.7834 Ext 277 *|* f: 208.882.1744*
> *From:* vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] *On Behalf
> Of *chan213419
> *Sent:* Monday, April 29, 2013 6:05 AM
> *To:* vantage@yahoogroups.com
> *Subject:* [Vantage] Quick Search Parameter: Workflow Group
> Good morning everyone!
> Question: Is it not possible to create a QS with WorkFlowGroupID as a
> parameter?
> I created a Quick Search filtered by WorkFlowGroupID. I created the QS
> filter as a prompt, and it seemed everything went well. When I run the QS,
> the prompt comes up as a "Workflow Group" button. I click the button,
> select my value, and run the search. The results returned as if I never
> chose the WorkflowGroupID; meaning that all WorkGroupIDs were returned.
> Another interesting thing: usually when I create prompt parameters and they
> appear as buttons, there is a txtbox next to them that shows the value
> chosen. Next to the Workflow Group search button there is no txtbox. I have
> also tried this on multiple versions of Epicor, and I get the same result.
> Your thoughts/ideas are much appreciated :)
Question: Is it not possible to create a QS with WorkFlowGroupID as a parameter?
I created a Quick Search filtered by WorkFlowGroupID. I created the QS filter as a prompt, and it seemed everything went well. When I run the QS, the prompt comes up as a "Workflow Group" button. I click the button, select my value, and run the search. The results returned as if I never chose the WorkflowGroupID; meaning that all WorkGroupIDs were returned.
Another interesting thing: usually when I create prompt parameters and they appear as buttons, there is a txtbox next to them that shows the value chosen. Next to the Workflow Group search button there is no txtbox. I have also tried this on multiple versions of Epicor, and I get the same result.
What I�ve found is that if you do an outer join on your QS BAQ, it will
Of *chan213419
parameter?
