Quick way to re-direct clients to new db?
Hello Everyone,
I recently moved a 6.x customer from one server to another...here's the
registry tool you can use to make life easier:
RegReplace
http://bladesdev.com/regreplace.htm
Very easy and fast...can be loaded from the server and then ran
simultaneously...
What happens is because there are references to the old server in the
registry Vantage tries to use those first before realizing it doesn't
exist and then hits the right one....
One tip...while you're moving things around, power down the old server
so you can verify that you are indeed hitting the new server...
Jason Claggett
Microsoft Small Business Specialist
MCP #3856159
2W Technologies, LLC
317.578.2393
jason@...
Of Todd Caughey
Sent: Thursday, July 05, 2007 4:35 PM
Subject: RE: [Vantage] Re: Quick way to re-direct clients to new db?
One warning....this method leaves references to the old server in places
that can cause problems if the old server is removed from the network
(or shutdown). If I recall correctly references in the HOSTS (or was it
SERVICES ?) file can cause confusion and at best cause Vantage to start
and run seriously slowly..or at worst not at all. Try is out on one or
two then turn the old server off and see if they can start Vantage
before you roll it out to a lot of them. There might also be some
registry references too. The uninstall/reinstall of the client handles
all this a lot better although it is a lot more work to do. Just a
potential "gotcha" to watch out for.
-Todd C.
Behalf Of crypticsphere
Sent: Thursday, July 05, 2007 3:16 PM
Subject: [Vantage] Re: Quick way to re-direct clients to new db?
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
<mailto:vantage%40yahoogroups.com>, "crypticsphere" <james.hill@...>
wrote:
> Is there a way to edit the progress install on all the clients / all
> the mfgsys installs on the clients to point to a new server? Just a
> shot in the dark before I start looking to find a way without having
> to run the install via the network. Running 6.1 just trying to find
> out if this can be done.
> thanks,
> James
I will answer it myself!
Ok, right click vantage icon, click on edit and change paths to new
server / and put new mapped drives.
The information contained in this E-mail message and any documents which
may be attached are privileged and confidential, and may be protected
from disclosure.
Please be aware that any use, printing, copying, disclosure or
dissemination of this communication may be subject to legal restriction
or sanction. If you think you have received this message in error,
please reply to the sender.
For more information please visit www.harveyvogel.com
thanks,
James
> thanks,
> James
Be careful, the progress install paths out several dlls in the registry.
Try searching thru the client registry for "\ \ {old server name} \ and
see what you get.
Even though your icon change appears to work your registry will be
searching the old server for files.
Patrick J. Winter
Information Technology Manager
Of crypticsphere
> thanks,
> James
This e-mail and any attachments may contain confidential and
privileged information. If you are not the intended recipient,
please notify the sender immediately by return e-mail, delete this
e-mail and destroy any copies. Any dissemination or use of this
information by a person other than the intended recipient is
unauthorized and may be illegal.
One warning....this method leaves references to the old server in places that can cause problems if the old server is removed from the network (or shutdown). If I recall correctly references in the HOSTS (or was it SERVICES ?) file can cause confusion and at best cause Vantage to start and run seriously slowly..or at worst not at all. Try is out on one or two then turn the old server off and see if they can start Vantage before you roll it out to a lot of them. There might also be some registry references too. The uninstall/reinstall of the client handles all this a lot better although it is a lot more work to do. Just a potential "gotcha" to watch out for.
-Todd C.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of crypticsphere
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, "crypticsphere" <james.hill@...> wrote:
> thanks,
> James
The information contained in this E-mail message and any documents which may be attached are privileged and confidential, and may be protected from disclosure.
Please be aware that any use, printing, copying, disclosure or dissemination of this communication may be subject to legal restriction or sanction. If you think you have received this message in error, please reply to the sender.
