Quicksearch by ClassID
OK. The outer join is nice, but now my "Quick Search" is returning
multiple results, e.g., I do a search for the PartGroup "Raw Material"
and it returns all parts in "Raw Material," but on occasion it returns
4 of the sames parts, same partnumber, same bin, etc.
--SF
--- In vantage@yahoogroups.com, "uscvantageuser" <uscvantageuser@...>
wrote:
> --- In vantage@yahoogroups.com, "sanfranc415" <sanfranc415@>
> wrote:
> > I'm working on a Quick Search that will bring up all the parts,
> > location, and quantity for a given Part Class.
> > I created a Quick search, added the Part Tracker BAQ, set to prompt
> > for Part ClassID, added the PartWhse table.
> > For some reason when I run this search, it doesn't bring up all the
> > parts in a class.
> > Thanks,
> > Running version 8.03.403D
> > --SF
> Did you do an outer join for the partwhse table when you set up your
> BAQ? In Phrase Builder there is a field, outer join, in Table
> Relations that asks you whether your doing an outer join to the
> parent tables children. Since you want to see all parts regardless
> if they have a partwhse or not, you need to specify outer join. The
> default is inner join.
parts in a class.
--SF
--- In vantage@yahoogroups.com, "sanfranc415" <sanfranc415@...>
> parts in a class.
> Thanks,
> --SF
