When I attach a file in quote entry and save the quote, I get the
following error message:
First a change log appears, and then:
The following application error was encountered:
Object reference not set to an instance of an object.Error Detail
Stack Trace
at
Epicor.Mfg.UI.FrameWork.EpiUltraGrid.getSingleRowProps(UltraGridRow ugr)
at
Epicor.Mfg.UI.FrameWork.EpiUltraGrid.resetPropsOnVisibleOrReadOnlyChange()
This is with the base module and no customizations.
--SF
Stack Trace
at
at
--SF
