Thanks Charles for your input.
I have created a new empty database and the errors in the appserver
log file go away so it doesn't seem to be related to the setup of the
server. As soon as I convert our .305K database to use with .404a
these "Decrypt..." error surface. I wonder how may others are
experiencing this but just don't look at this log file.
Everything seems to run fine within Vantage but we are only testing
with .400 at this point.
Are you live on .400? Are you just ignoring the log file?
--- In vantage@yahoogroups.com, "Charles Carden" <shadow031449@...> wrote:
> I have had the same error since upgrading to 8.03.403x. I called
Epicor and
> they indicated it is a progress error. The resolution from Progress
is to
> recompile the program causing the error. I thought at one time it
might be
> caused by the conversion of passwords. I reentered the passwords in
System
> Agent but that still did not resolve it. I have not found that the
error
> causes problems but then who knows what is really happening in the
> background. It does not appear that Epicor is too eager to fix it
whatever
> it is. Try submitting it to support. Maybe you will have better
luck that
> I did.
> _____
Behalf Of
> hoomail4me
> Sent: Thursday, April 10, 2008 2:40 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Quote Entry - Error attaching a file. -
server.log
> Our MfgSys803TaskAgent.log file is filling up with these errors:
> [08/04/09@19:52:54.595-0500] P-001428 T-004752 1 AS -- DECRYPT
> error:0606506D:digital envelope routines:EVP_DecryptFinal:wrong final
> block length:
> Anyone know what is going on? Working with Epicor but so far not answer.
> These error are on our .404a server that is a converted copy of our
> .305K database.
> Thanks,
> Bill
> --- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com,
> "sanfranc415" <sanfranc415@> wrote:
> > [07/12/17@11:12:29.235-0800] P-004852 T-007348 1 AS -- DECRYPT
> > block length:
> > > If I attach a file and save the quote, I get an error message, well
> > > first the Changes dialog box shows up, and then I get the following
> > > application error:
> > > The following application error was encountered:
> > > Object reference not set to an instance of an object.
> > > Stack Trace
> > > at
> > > Epicor.Mfg.UI.FrameWork.UltraGrid.getSingleRowProps(UltraGridRow
ugr)
> > > at
> Epicor.Mfg.UI.FrameWork.UltraGrid.resetPropsOnVisibleOrReadOnlyChange()
> > > Notes:
> > > I'm running 403D OpenEdge 10.1B SP2 (3 is the latest, but haven't
> > > updated yet).
> > > All other modules, e.g., Order Entry attachments work fine.
> > > File shows up as an attachment after going through all the
change log
> > > and application error.
> > > No customizations.
> > > No BAMs or change log enable for Quote Entry.
> > > Thanks,
> > > --SF
