Quote Entry -> Optimal Performance
Ok, so if we increase the client-side (quote user) hardware, i.e.,
upgrade processor and memory?
--jp
-- In vantage@yahoogroups.com, Robert Brown <robertb_versa@...> wrote:
> All multi-line/release entry apps (PO, Sales order, Quote)
noticeably slow at 25 lines/releases. Much more than 50 & they come to
a crawl.
> Pretty normal.
> It's all client side code issues from what I can tell so users of
these apps can greatly benefit from the hottest PC iron & network
connectivity you can muster (or afford).
> Rob
> --- On Mon, 1/19/09, sanfranc415 <sanfranc415@...> wrote:
> From: sanfranc415 <sanfranc415@...>
> Subject: [Vantage] Quote Entry -> Optimal Performance
> To: vantage@yahoogroups.com
> Date: Monday, January 19, 2009, 2:36 PM
> We have a user that is working in a quote which has 960 lines. She is
> created Orders from this quote, but it seems unbearable slow. Epicor
> says that since it needs to re-validate ever line when a new line is
> created, it is very surprising it's running slowly.
> Feedback would be nice.
> Regards,
> --sf
Regards,
--sf
We had that issue not too long ago, the culprit turned out to be a reference to a non-vantage SQL database (i.e., not mfgsys803). After the reference was removed, the speeds improved substantially.
Kunal
Sent: Monday, January 19, 2009 1:36:39 PM
Regards,
--sf
All multi-line/release entry apps (PO, Sales order, Quote) noticeably slow at 25 lines/releases. Much more than 50 & they come to a crawl.
Pretty normal.
It's all client side code issues from what I can tell so users of these apps can greatly benefit from the hottest PC iron & network connectivity you can muster (or afford).
Rob
Regards,
--sf
Pretty normal.
Rob
Regards,
--sf
