Just another problem with no common denominator.
~Charlie
_____
Rob Bucek
Sent: Friday, May 01, 2009 12:10 PM
Subject: RE: [Vantage] Re: Quote Form Data Defintion
You guys may be hitting on something...Ill look around to see if ive
done that in more than one RDD. Perhaps there is some other variable
that we haven't hit on yet that causes it to work in some instances but
not others..
Rob Bucek
Manufacturing Engineer
PH: 715-284-5376 ext 311
FAX: 715-284-4084
<http://www.dsmfg. <http://www.dsmfg.com/> com/>
(Click the logo to view our site)
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
Behalf
Of Lynn
Sent: Friday, May 01, 2009 10:09 AM
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
Subject: [Vantage] Re: Quote Form Data Defintion
I've had inconsistent results.
A couple of times , it would allow me to link a 3rd table to a 2nd
(newly-added) table. But most of the time, I get the same results as
Ross. The 3rd table returns no data.
I'm on 8.03.404.
Lynn
--- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
<mailto:vantage%40yahoogroups.com> , "Rob
<mailto:vantage%40yahoogroups.com> ] On
Behalf
<http://groups. <http://groups.yahoo.com/group/vantage/files/>
yahoo.com/group/vantage/files/> >
<http://groups. <http://groups.yahoo.com/group/vantage/messages>
yahoo.com/group/vantage/messages> >
<http://groups. <http://groups.yahoo.com/group/vantage/linksYahoo>
yahoo.com/group/vantage/linksYahoo> > ! Groups Links
~Charlie
_____
Rob Bucek
not others..
Rob Bucek
FAX: 715-284-4084
Behalf
Of Lynn
I'm on 8.03.404.
Lynn
><http://www.dsmfg.com/> com/> >
> I thought I did something like that from the RDD BOLForm (made a
> duplicate of and then..), I went BOLDtl to ShipHead, ShipHead to
> ShipDtl, and ShipDtl to Part. Works great....
> Rob Bucek
> FAX: 715-284-4084
> <http://www.dsmfg. <http://www.dsmfg.com/> com/ <http://www.dsmfg.
Behalf
> Of Ross Hughes<mailto:vantage%40yahoogroups.com>
> Sent: Friday, May 01, 2009 9:47 AM
> Subject: RE: [Vantage] Re: Quote Form Data Defintionto
> I just ran in to that as well.
> What I concluded is that RDD will not allow a dual-chain manual
> relationship. It consistently will not provide data on second table in
> the
> manually-created relationship.
> I can always get data in the first table but not the second.
> A cheating (and inefficient) workaround (if the table is small) is to
> hang
> the table off the Company table (or another if you can reduce the
> dataset)
> and only relate the Company field (or others that assist in the
> reduction of
> data). Of course, this gives you the 10-pound XML file that you have
> filter off in Crystal.<mailto:vantage%40yahoogroups.com>
> An option...not the best but I have used it in a pinch and it works.
> Maybe I am doing something wrong. Epicor support couldn't not get the
> data
> to return in the second table.
> Is anyone else getting data in the second added table?
> Ross
> -----Original Message-----
> [mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com<mailto:vantage%40yahoogroups.com>
> Behalf Of<mailto:vantage%40yahoogroups.com>
> Lynn
> Sent: Friday, May 01, 2009 9:08 AM
> Subject: [Vantage] Re: Quote Form Data Defintionon
> According to the Vantage 8 data dictionary, QuoteCnt.ConNum and
> CustCnt.ConNum are system-generated numbers. If you relate those 2
> tables
> via the ConNum field, you would get unexpected results.
> For example, QuoteCnt.ConNum = 1 will be Jane Smith.
> But CustCnt.ConNum = 1 will be John Doe.
> They won't be the same person.
> I'm not sure what you are trying to show on your CR quote form.
> But, if you are simply trying to list all possible customer contacts
> your<mailto:vantage%40yahoogroups.com>
> quote form, perhaps you really want to relate the QuoteHed to CustCnt
> using
> the fields: Company, CustNum, (& possibly ShipToNum).
> Lynn
> "Charlie Wilson" <foamdesigncsw@> wrote:ConNum.
> > I'm working on adding a couple fields to the quote form data def. I
> had to
> > add a couple tables to get to the data I want. I added QuoteCnt and
> CustCnt.
> > I built a relationship from Quotehed to QuoteCnt using the QuoteNum
> field
> > and then one from QuoteCnt to CustCnt table using Custnum and
> I'mit
> > getting data in the QuoteCnt table but the CustCnt table come up
> blank. I
> > have confirmed that there is relative data that should be there but
> isn'there?
> > showing up. Can anyone give me any advice as to what is going on
> >yahoo.com/group/vantage/files/.
> > ~Charlie
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> have
> (1) To access the Files Section of our Yahoo!Group for Report Builder
> and
> <http://groups. <http://groups.yahoo.com/group/vantage/files/>yahoo.com/group/vantage/files/
> (2) To search through old msg's goto:yahoo.com/group/vantage/messages
> <http://groups. <http://groups.yahoo.com/group/vantage/messages>yahoo.com/group/vantage/messages
> (3) To view links to Vendors that provide Vantage services goto:yahoo.com/group/vantage/linksYahoo
> <http://groups. <http://groups.yahoo.com/group/vantage/linksYahoo>yahoo.com/group/vantage/linksYahoo
