Thanks Ross & Ken,
I see it now on the Customer detail screen. I found no literature on the use of this capability and did not notice the field. This will help a lot.
Thanks again,
Dave
8.03.407C P
Thanks again,
Dave
8.03.407C P
--- In vantage@yahoogroups.com, "Ross Hughes" <ross.hughes@...> wrote:
> In Quote/Setup you can configure quote markup tables. These can them be
> tied to each customer on the main page in customer maintenance.
> When you add a new line or quote quantity this quote markup % will default
> on the quote line.
> That should take care of a default per customer.
> If you get to a point where you want to change a percentage once the 40
> lines are entered you will need to do that manually or write some custom
> code to change them in one sweep.
> Ross
> -----Original Message-----
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> ofcwiz
> Sent: Thursday, May 06, 2010 9:16 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Quote markup
> Does anyone know how to apply a markup percentage to a quote such that it
> does not have to be applied to each line?
> I find where a quote markup can be applied at the line level,
> Quote-Line-worksheet-markup. But cannot locate where this might be applied
> to a Customer or to the Quote header. This turns out to be real tedious for
> a quote with 40 lines.
> Thanks,
> Dave
> 8.03.407C P
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
