Tim, you're welcome. One final note I forgot to mention, your barcode
scanners will also need to be configured to enable "Code 39 Full ASCII
Conversion".
If you happen to have Symbol scanners, there is a document also in that
folder called LS2208 Initial Setup. Check out Page 5.
Tim Vonderhaar
Sent: Tuesday, November 06, 2012 3:56 PM
Subject: [Vantage] Re: Quote symbols in part numbers and Crystal Barcodes
Outstanding! Thanks so much for the help.
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Vic
Drecchio" <vic.drecchio@...> wrote:
Behalf Of
Checked by AVG - www.avg.com
Version: 2012.0.2221 / Virus Database: 2441/5377 - Release Date: 11/06/12
No virus found in this message.
Conversion".
Tim Vonderhaar
>http://f1.grp.yahoofs.com/v1/QGyZUCAgqtE_uQrcO6mCr8VXxhobzVpLp5YTC9YvfbvJrjZ
> Tim, take a look at this:
>Lb_-bg5QHfhkrIhDXiBdtNYRJY6OR_CbPPbiTX2vqXBS0-mc/Barcoding/Special%20Barcode
> %20Characters.pdf[mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> If it doesn't come across correctly go here:
> http://tech.groups.yahoo.com/group/vantage/files/Barcoding/
> Open up Special Barcoding Characters.
> In Crystal, create a formula for your barcoded partnumber. Use the
> Replace() function in CR to change any quotes (") to a /B as shown on that
> PDF referenced above.
> Let me know if you need more help.
Behalf Of
> Tim Vonderhaarbut
> Sent: Tuesday, November 06, 2012 3:44 PM
> Subject: [Vantage] Quote symbols in part numbers and Crystal Barcodes
> We have stumbled into a Crystal barcode problem when part numbers contain
> certain characters like a quote ("). Many of our legacy cable assemblies
> include the quote symbol character in the part number reflecting length in
> inches. Epicor didn't have a problem with the part number during import,
> Crystal doesn't want to display the barcode for it. It simply shows up asa
> quote symbol in the midst of the entire barcode. Any ideas or workarounds?
> Thanks,
> Tim
