Radio Button Default
Does any know how I can change the default of a radio button? I want the default on the PO line form to be Inventory instead of other.
That one defaults to things based on your part settings. Our defaults to inventory. Non-quantity bearing parts (or parts on the fly) will force you to other. If they are quantity bearing part numbers, it doesn’t look like it even lets you choose other.
Is there also a way to have parts not in part master default to “Job Material”?
If the demand is coming from the job. You have to build the job, and have the purchase suggestions generated, or manually input the job asm and mtl sequences. If you go with the purchase suggestions, these will automatically set it to job material.
