Thanks Gordon. That was exactly it.
Was sorting on a desc field that usually works. Extra long data was added
this month.
Thanks again.
Jim
Sent: Monday, June 30, 2003 9:31 AM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] RB Error Help
When I see this error it's because I'm trying to sort on a field that
contains a value that is too long. For instance, when I try to sort all
parts by description, and someone has created a part with a couple of
paragraphs of text for a description. RB chokes on this.
To work around:
(1) create a quick report that shows what the offending value is:
Calculated Field: DescriptionLength = LENGTH(PartDescription), Filter:
DescriptionLength > 100
(2) Even better: Instead of sorting on the field which could potentially be
too long, replace the field in your report with a calculated field called
ShortPartDesc, Expression: SUBSTRING(PartDescripton,1,50). This calculation
only takes the first 50 characters of the long field and sorts on that.
Gord Schindell
Network Admininstrator
Almac Machine Works.
From: Moore, Jim (Anniston) [mailto:jmoore@...-ots.com]
Sent: Monday, June 30, 2003 8:05 AM
Subject: [Vantage] RB Error Help
I have a RB report that has run for a while now that started giving the user
this error. "Database request failed. Database error is: ** Index value is
too long. (141)
This report is a Monthly Shipping Report and the filter that seems to be the
problem is Shiphead.ShipDate IN-RANGE 05/26/2003, 06/26/2003
An earlier date range worked fine. (The one in 2001 that was there when the
report was created.
Any idea what has happened. Nothing has changed on this report in a long
time.
Jim Moore
GD-OTS
this month.
Thanks again.
Jim
To work around:
Gord Schindell
too long. (141)
report was created.
time.
Jim Moore
GD-OTS
