RB error -tok parameter
-tok is a startup parameter. Can be put into a .pf file or a .vtg file.
Default = 1024.
4.0 max = 1600.
5.0 max is system dependant depending on available memory.
Jim
Sent: Monday, February 17, 2003 3:24 PM
Subject: RE: [Vantage] RB error -tok parameter
Patrick,
Thank you, that let me get in that last join. It should let me put back
in
the company joins as well to speed things back up. I used -tok 2048.
Is
anyone aware of any negative impact of this choice? For now, I am just
very
grateful that it works.
Aaron Hoyt
Design Standards
Sent: Monday, February 17, 2003 4:09 PM
To: 'vantage@yahoogroups.com'
Try the -tok option on the Report Builder.vtg ConnectOptions line.
Patrick Winter
Sent: Monday, February 17, 2003 3:00 PM
That is a good call, and exactly where I am at, no table has more than 3
characters as it's alias. I will try to cut them to 2 and see if I can
squeeze in the last couple of joins. Thanks
Sent: Monday, February 17, 2003 3:50 PM
If you have a ton of joins and this is where you are getting this
message
here is a work around. Rename some of the key tables with aliases such
as
"part" to "P", "JobHead" to "JH", etc... All it does is save on
characters
so you can add more statements. Keep in mind that joins use multiple
fields
so each occurace of the table name is reduced in character length.
Patrick Winter
Sent: Monday, February 17, 2003 2:42 PM
To: 'Vantage E-Group (E-mail) ' (E-mail)
Subject: [Vantage] RB error -tok parameter
I am getting the following error when running a RB report that I am
building. "Database error is: **More than 1024 items in a single
statement.
Use the -tok parameter. (136) **" Anyone know where to enter this
parameter,
if I can change it, or if I am just stuck having to keep down the number
of
joins? Any help is appreciated. Thank you,
Aaron Hoyt
Design Standards
have
and
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
have
and
have
and
have
and
building.
"Database error is: **More than 1024 items in a single statement. Use
Anyone know where to enter this parameter, if I can change it, or if I am
just stuck having to keep down the number of joins?
Thank you,
Aaron Hoyt
Design Standards
If you have a ton of joins and this is where you are getting this message
here is a work around. Rename some of the key tables with aliases such as
"part" to "P", "JobHead" to "JH", etc... All it does is save on characters
so you can add more statements. Keep in mind that joins use multiple fields
Patrick Winter
building. "Database error is: **More than 1024 items in a single statement.
Use the -tok parameter. (136) **" Anyone know where to enter this parameter,
if I can change it, or if I am just stuck having to keep down the number of
Aaron Hoyt
Design Standards
------------------------ Yahoo! Groups Sponsor ---------------------~--> Get
128 Bit SSL Encryption!
http://us.click.yahoo.com/FpY02D/vN2EAA/xGHJAA/PhFolB/TM
Patrick Winter
Aaron Hoyt
Design Standards
Patrick Winter
Patrick Winter
Aaron Hoyt
Design Standards
Patrick,
Thank you, that let me get in that last join. It should let me put back in
the company joins as well to speed things back up. I used -tok 2048. Is
anyone aware of any negative impact of this choice? For now, I am just very
Aaron Hoyt
Design Standards
Patrick Winter
Patrick Winter
Aaron Hoyt
Design Standards
