RB Filter
An alternate means is to use the index function (which I commonly use in 4gl
development). The index function simply returns the position at which one
string occurs in another. It returns zero if the specified search string
doesn't exist in the source string.
For example:
Index( "01,02,03,04,23,24,56" , EmpBasic.EmpID) > 0
would return true if EmpID is found in the source string, which is the first
argument in this case
Thaddeus Jacobs
IT Developer
Kinematic Automation, Inc.
mailto:tjacobs@...
Message: 1
Date: Mon, 2 Dec 2002 07:38:41 -0500
Subject: RB Filter
Hope everyone had a great Thanksgiving! Hope that you all aren't too stuffed
and can walk into work this morning!
n RB filter ~s list. These employee numbers have nothing else in common, so
this is the only way I have been able to pull in only these employees so
far. I also created an exact duplicate of this filter but used my next set
of 12 values, but RB didn't like it. I have also tried using "not" for the
filter, but I have more "not" values that I would have to enter in than my
current filter setup.
Any ideas gang?
Wendy Bowen
Network Administrator
Schmald Tool & Die, Inc.
Burton, Michigan
Sent: Monday, December 02, 2002 12:25 PM
Subject: [Vantage] Digest Number 2173
There are 22 messages in this issue.
Topics in this digest:
1. RB Filter
2. RE: RB Filter
3. RE: RB Filter
4. RE: RB Filter
5. Re: RB Filter
6. RE: Vantage on Microsoft SQL Server
7. RE: 5.2 and Crystal Reports 9
8. is this some kind of virus?
9. Re: RB Filter
10. RE: VB Forms linking to Part Drawings, etc.
11. Re: Please HELP with RB question someone!!!!!!!
12. RE: is this some kind of virus?
13. RE: RB Filter
14. RE: RB Filter
15. RE: LaunchFile.i program
16. Re: is this some kind of virus?
17. RE: is this some kind of virus?
18. RE: is this some kind of virus?
19. Re: VB Forms linking to Part Drawings, etc.
20. Editing Crystal Form 5.1
21. Re: Editing Crystal Form 5.1
22. RE: Editing Crystal Form 5.1
________________________________________________________________________
Message: 1
Subject: RB Filter
and can walk into work this morning! heehee!
Anyway.............I have an RB filter that requires 22 "compared to"
values. It does not let me enter in all 22. It only lets me enter in up to
10. This is my current filter.
EmpBasic.EmpID IN-LIST '01','03','07','08','16','18','20','21','22','25'
Unfortunately I need to add 12 more values to this list. These employee
numbers have nothing else in common, so this is the only way I have been
able to pull in only these employees so far. I also created an exact
duplicate of this filter but used my next set of 12 values, but RB didn't
like it. I have also tried using "not" for the filter, but I have more "not"
values that I would have to enter in than my current filter setup.
Any ideas gang?
Wendy Bowen
Burton, Michigan
Message: 2
Date: Mon, 2 Dec 2002 07:48:45 -0500
Subject: RE: RB Filter
Wendy,
you could try,
t1 = iif(EmpBasic.EmpID = '01', 1, iif(EmpBasic.EmpID = '03', 1,
iif(EmpBasic.EmpID = '02', 1, 0)
t2 = iif(empBasic.empID = '08', 1, iif(EmpBasic.EmpId = '16', 1,
iif(EmpBasic.EmpID = '18', 1, 0)
t3 = iif(EmpBasic.EmpID = '21', 1, iif(EmpBasic.EmpID = '22', 1,
iif(EmpBasic.EmpID = '25', 1, 0)
t4 = iif(EmpBasic.EmpID = '26', 1, iif(EmpBasic.EmpID = '27', 1,
iif(EmpBasic.EmpID = '28', 1, 0)
Test = iif(t1 <> 0, 1, iif(t2 <> 0, 1, iif(t3 <> 0, 1, iif(t4 <> 0,
1, 0)
I think you get the idea. I've had to code like this in the past due to the
limitation of RB.
Good Luck,
Message: 3
Date: Mon, 2 Dec 2002 08:01:22 -0500
Wendy,
Another option I've used to overcome this limitation is "OR"
such as
OR
EmpBasic.EmpID IN-LIST '26','27','28','29','30','31','32','33','34','34'
OR
EmpBasic.EmpID IN-LIST '35','36','37','38','39','40','41','42','43','44'
If that's all the filter you have then it's a bit easier. However, if you
have more filters you have to duplicate your filter for each "OR" step.
Like this:
And
Empbasic.active =yes
OR
And
OR
And
If you have several layers of filters for each "OR" group then
Dick's solution is probably better.
Shirley
Sent: Monday, December 02, 2002 7:49 AM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] RB Filter
Wendy,
you could try,
1, 0)
limitation of RB.
Good Luck,
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://rd.yahoo.com/M=237459.2675695.4055211.2225243/D=egroupweb/S=17050071
83:HM/A=1267611/R=0/*http://ad.doubleclick.net/jump/N2524.Yahoo/B1071650;sz=
300x250;ord=1038833441368838?>
Message: 4
Date: Mon, 2 Dec 2002 08:07:02 -0600
You could create a logical function field and then test for "true" in the
filter. As long as there is not a requirement for the user running the
report to change the values. This might have a small impact on performance
though. For example:
In-List = IIF(EmpBasic.EmpID = '01' or
EmpBasic.EmpID = '03' or
EmpBasic.EmpID = '05' or
EmpBasic.EmpID = '08',
True, False)
Specifically to employees I added at check-box VB Form field on Shop
Employee to exclude specific employees from certain efficiency reports. The
production managers can maintain the elligibility themselves. Then I test
for the EmpBasic.CheckBox1 = 'True' in the filter. I also made a report for
them to list all employees with a given checkbox entry.
-Todd C.
Sent: Monday, December 02, 2002 6:39 AM
Subject: [Vantage] RB Filter
Any ideas gang?
Wendy Bowen
Burton, Michigan
ADVERTISEMENT
300x250;ord=1038832782395579?>
<http://us.adserver.yahoo.com/l?M=237459.2675695.4055211.2225243/D=egroupmai
l/S=:HM/A=1267611/rand=194422527>
Message: 5
Date: Mon, 2 Dec 2002 09:17:45 -0500
Subject: Re: RB Filter
Do you mean that I should make these as calculations? Then make one final
"test" calculation and make that the filter? I guess I'm not following
exactly what you mean this morning. It's a Monday....heehee!
Wendy Bowen
----- Original Message -----
Sent: Monday, December 02, 2002 7:48 AM
Wendy,
you could try,
1, 0)
the
limitation of RB.
Good Luck,
ADVERTISEMENT
Message: 6
Date: Mon, 2 Dec 2002 09:18:49 -0500
Subject: RE: Vantage on Microsoft SQL Server
We migrated to SQL Server and was there for 6 months. We went back to
Progress in March of this year. We have one of the fastest networks and
servers possible and it was still allot slower then Progress. We eventually
got the speed to an acceptable level. Our problem was with data corruption.
It seemed like almost every time we applied a patch it would corrupt
something. We are still dealing with problems that was caused by the time
spent on SQL Server. When we made the change back in March, I was told that
there was no other SQL Server users left. I also was frustrated when
calling Tech support. When I mentioned that I was on SQL Server, I often
imagined the Tech support person with the "deer in the headlights" look
about them. One way I got by allot of the speed issues was to run as many
users as possible on Terminal Services from the Vantage server. Although
you should normally not run server applications such as SQL Server on a
Terminal server, this was one of the few things I could do that made a huge
difference.
A few other things that where problems.
1) Priority dispatch report that takes 30 sec on Progress takes 30-45
minutes on SQL Server
2) Global Finite Scheduling took over 24 hours to run.
3) Installation and upgrade instructions where obviously untested.
Hope you have better luck then we did. I have a Priority Dispatch report
written in MS Access 2000 that runs on SQL Server much faster then the
Vantage report if you would like a copy of it. I believe I still have a
copy of all of our custom reports written in Access if you would like them
let me know.
If you have any questions, feel free to give me a call.
Jeremy Leonard
IT Manager
K-T Corporation
317-398-6684
Sent: Wednesday, November 27, 2002 8:00 AM
Subject: [Vantage] Vantage on Microsoft SQL Server
Hi all,
Is anyone out there using the version of Vantage that runs on Microsoft
SQL? We are thinking of moving to it. I would like to hear about any
problems or performance issues from anyone using it. I would also like
to hear about the Progress to SQL conversion process.
Chris
Message: 7
Date: Mon, 2 Dec 2002 08:43:52 -0600
Subject: RE: 5.2 and Crystal Reports 9
Crystal 8.5 is also the recommended version for Vantage 6.0 due out in
Februaryish, so you may be out on your own if your attempting Crystal 9 with
Vantage.
Sent: Wednesday, November 27, 2002 8:19 AM
Subject: RE: [Vantage] 5.2 and Crystal Reports 9
We bought version 9 and then discovered the reports did not work in 5.2, and
when support was asked they told us we had to get 8.5 because 9 was not
supported. We purchased a downgrade to version 8.5 to be supported with
5.2 and I believe the cost was around $50.
Mark S. LaRosa
MIS Manager
R&R Manufacturing Co., Inc.
Phone: 203.888.2133
Fax: 203.888.9860
Sent: Tuesday, November 26, 2002 6:20 PM
To: Vantage Onelist (vantage@onelist.com)
Subject: [Vantage] 5.2 and Crystal Reports 9
Will version 9 of Crystal Reports work with Vantage 5.2? What is the
recommended version?
Lori
Lori A. Baker
Director of Information Systems
WindStone Medical Inc. (formerly Cardio Pak Inc.)
406.259.6387
lbaker@... <mailto:lbaker@...>
www.windstonemedical.com <http://www.windstonemedical.com/>
ADVERTISEMENT
Message: 8
Date: Mon, 2 Dec 2002 08:45:52 -0600
Subject: is this some kind of virus?
I recieved an email the other day with the title "Set Cookie ()"
this email stated that I had set this original email out which I did not.
Is somthing going around that we need to know about?
Chad
Message: 9
Date: Mon, 02 Dec 2002 09:48:19 -0500
At 07:38 AM 12/2/2002 -0500, you wrote:
>I have an RB filter that requires 22 "compared to" values. It does not
>let me enter in all 22. It only lets me enter in up to 10. This is my
>current filter.
How about using a field in a VB Form to flag the employees to be
included? Then just filter like: EmpBasic.Character01 = 'A' or
whatever. It would be easier to maintain in the future, and the best part
- you can delegate it to your HR people or whomever; instead of having to
mess with it yourself every time employees come or go :)
If you use one of the filter options suggested, be sure to put ( parens )
around the ORs to keep your other conditions working.
-Wayne Cox
Twenty Three - Information Technology Consulting
828-685-2338
Message: 10
Date: Mon, 2 Dec 2002 08:50:59 -0600
Subject: RE: VB Forms linking to Part Drawings, etc.
This will be pretty cool in version 6.0 when you can move the VBFORM button
to the front screen where it's needed and even change the TAB order of the
screen to include it.
Patrick
Sent: Wednesday, November 27, 2002 4:20 PM
Subject: RE: [Vantage] VB Forms linking to Part Drawings, etc.
Yes it can be done. I currently link our SPC charts/graphs/data to a button
on the Job Tracker - Operation level VB-Form so that you can view the most
recent SPC graphs/data for that specific operation.
Set the button on the VB-Form with the RUNPROG vdp/program.p
In the program.p, do a FIND vantage-table WHERE ROWID(vantage-table) =
GetCurrentRowID() no-lock.
This will set you program so that it has the current record from which the
VB-Form is from.
Then just do a DOS SILENT command to launch your external program.
Sent: Wednesday, November 27, 2002 3:51 PM
To: Vantage
Subject: [Vantage] VB Forms linking to Part Drawings, etc.
Has anyone successfully linked a VB Form to a procedure which can identify a
specific filename... based on a current field referenced by the current
table in the VB Form? I'd love to discuss details with you if possible.
We would like to have a VB Form which does the following:
1. From the Inspection Receipt screen, with PartNum "ABC" selected,
2. Click the VB Forms button.
3. Click a XLS button on the VB Form, which activates a progress program,
which retrieves the "ABC.xls" file from the server and opens it in Excel.
4. There would also be a DWG button on the VB Form, which when activate,
would retrieve the "ABC.dwg" CAD file in either autocad or an autocad
viewer.
Does anyone know what progress procedure would do such a thing?
Troy
Message: 11
Date: Mon, 02 Dec 2002 14:58:35 -0000
Subject: Re: Please HELP with RB question someone!!!!!!!
Mark,
The proper way to say "Not Equal to" in a formula is <>.
HTH,
Brian Stenglein
--- In vantage@y..., Mark Howard <mhoward@j...> wrote:
> I am have a real problem with a part of a formula, I have product
group
> ranges and different ranges belong to different production areas.
I have
> some quirky product that fall within a particular product group but
are
> really part of a different area. The only way I can flag them is in
the Part
> master file use one of the Character field and type something like
BH......
> My problem is when I add in my formula to excluded a particular
item that is
> in that group but has an BH in the user field I get a syntax error
you can
> see below the part of the formula that is causing me a problem...
> I need the formula to look at the particular range of product code
and if it
> fall within these codes BUT has a BH in the user field to exclude
it from
> the group..... I need a function Part.UserChar3 Not = "BH" but this
doesn't
> work any other way of doing a Not = to??
> iIf ((Description>="sp01000"and Description<="sp01099") or
> (Description>="sp01300"and Description<="sp01699") and
(Part.UserChar3 not =
> 'BH' ) , "Ecavator SP01000-SP01099 SP01300-SP01699")
> PG1
(Part.UserChar3 Not
> = "BH ") , "Ecavator SP01000-SP01099 SP01300-SP01699",iif
> ((Description>="sp01100"and description<="sp01199") or (description
> >="sp08100"and description<="sp08199") , "Quick Hitch SP01100-
SP01199
> SP08100-SP08199", "" ))
> PG2
> iIf ((Description>="sp07400"and Description<="sp07799")or
> (Description>="sp08000"and Description<="sp08099")or
> (description>="sp08200"and description<="sp08599") or
(Part.UserChar3 =
> "BH"), "Backhoe SP07400-SP07799 SP08000-SP08099 SP08200-
SP08599",iif
> (Description>="sp02000"and description<="sp02099" , "Long Reach
> SP02000-SP02099", iif(Description>="sp02100"and
description<="sp02299" ,
> "Ext. Boom SP02100-SP02299 ", "")))
> Mark Howard
> Financial Controller
> Jaws Buckets & Attachments
> This email, together with any attachments, is intended for the named
> recipient(s) only and may contain privileged and confidential
information.
> No information within this email can be forwarded via email or
verbally
> without the consent of the sender.
> If not an intended recipient of this email, you must not copy,
distribute or
> rely upon it and any form of disclosure, modification, distribution
and/or
> publication of this email is prohibited.
> Unless stated otherwise, this email represents only the views of
the sender
> and not the views of Jaws Buckets & Attachments.
Message: 12
Date: Mon, 2 Dec 2002 10:00:17 -0500
Subject: RE: is this some kind of virus?
When in doubt, delete it out!!
Shirley
Sent: Monday, December 02, 2002 9:46 AM
To: One list (E-mail)
Subject: [Vantage] is this some kind of virus?
Chad
ADVERTISEMENT
300x250;ord=1038840338676603?>
Message: 13
Date: Mon, 2 Dec 2002 09:29:29 -0600
Someone here found a way around the limit in the filter listing. If you put
your choices in until you hit the limit, then go into another filter, then
go back to edit your limited filter, it lets you keep going with more
entries. I don't know if you hit some new limit or not, but it has worked
for us so far.
Nora Story
Spectra Technologies, Inc.
Message: 14
Date: Mon, 2 Dec 2002 09:45:50 -0600
Another trick is to rename your tables with ALIAS's which are much shorter
leaving you more room to work.
Patrick
Sent: Monday, December 02, 2002 9:29 AM
for us so far.
Nora Story
Message: 15
Date: Mon, 2 Dec 2002 08:16:46 -0800
Subject: RE: LaunchFile.i program
Troy,
How was your thanksgiving weekend? Mine was pretty cool. My sister's
fiance moved in with me over the weekend, so it wasn't 100% vacation, but I
was able to get alot done.
I think all that's left to do is define the variable.
{vbp\LaunchFile.i}
DEF VAR File-Name AS CHAR.
ASSIGN File-Name = "C:\" + Part.PartNum + ".xls".
RUN LaunchFile (File-Name).
Let me know if that works,
Thaddeus
Sent: Thursday, November 28, 2002 12:00 AM
To: Thad Jacobs
Cc: Thaddeus Jacobs
Subject: LaunchFile.i program
Hi Thad,
Hoping you're having a great thanksgiving.
I've been fiddling with your LaunchFile.i program for use in a VBForm,
rather than from a Vantage menu.
By adding the {vbp\LaunchFile.i} to my progress procedure I can call a
filename like "C:\sample.xls" with no problem. Is there a way for the
LaunchFile.i program to handle a variable name instead of a literal file
name?
What I'd like to do is something like:
Do you have any ideas?
Troy Funte
Liberty Electronics
Message: 16
Date: Mon, 2 Dec 2002 08:41:35 -0800 (PST)
Subject: Re: is this some kind of virus?
Hi, Chad -
As someone said, if you don't know what it is, delete it - my personal rule!
If you're curious, though, the symantec virus encyclopedia can usually fill
you in on up to date virus info
http://securityresponse.symantec.com/avcenter/vinfodb.html/
Chad Duwe <chadd@...> wrote:I recieved an email the other day with
Chad
Yahoo! Groups SponsorADVERTISEMENT
Do you Yahoo!?
Yahoo! Mail Plus - Powerful. Affordable. Sign up now
Message: 17
Date: Mon, 2 Dec 2002 11:55:04 -0500
That could also be some sort of spam gone wrong. Like the spammer was trying
to set a cookie on your system and it didn't work.
Still better to be safe and check the anti-virus sites and see if there are
any known viruses (virii?) that do what you are describing.
Brian Boyes,
Systems Administrator,
Precision Resource Canada Ltd.
<http://www.precisionresource.com>
<mailto:brianb@...>
Message: 18
Date: Mon, 2 Dec 2002 11:37:34 -0600
let me clarify...the system email administrator is telling me that this 'set
cookie' email is undeliverable because there is no such address. the thing
is I never sent the email to begin with.
whats up with that?!
CDuwe
Sent: Monday, December 02, 2002 8:46 AM
Chad
ADVERTISEMENT
l/S=:HM/A=1267611/rand=538943082>
Message: 19
Date: Mon, 2 Dec 2002 12:47:02 -0500
Subject: Re: VB Forms linking to Part Drawings, etc.
That will definitely be a nice option, as long as it is not manditory.
Troy Funte
Liberty Electronics
Sent: Monday, December 02, 2002 9:50 AM
button
Patrick
button
VB-Form is from.
To: Vantage
a
viewer.
Troy
have
have
ADVERTISEMENT
Message: 20
Date: Mon, 2 Dec 2002 13:33:55 -0600
Subject: Editing Crystal Form 5.1
Stupid Question here. I can't seem to see labels when I run a RFQ
Report but when I run it on another PC it is fine. The trouble started
when I was trying to edit the form. I never saved any of my changes but
now I can't see any labels. I have copied that person's vngtwk51
directory to my machine no luck. Any ideas?
Thanks!
Juliet
Message: 21
Date: Mon, 2 Dec 2002 15:00:16 -0500
Subject: Re: Editing Crystal Form 5.1
Juliet,
You may have to Open Crystal Designer, then click Database / Set
Location. Then point each of the tables listed there to the c:\vntgwk51 (or
however you spell it) folder). It is safe to go ahead and save the report
pointing to that location since Vantage will tell the report where to look
when the report is actually run from Vantage. The default is usually
c:\temp for the "Set Location" option.
Troy Funte
Liberty Electronics
Sent: Monday, December 02, 2002 2:33 PM
Subject: [Vantage] Editing Crystal Form 5.1
Thanks!
Juliet
ADVERTISEMENT
Message: 22
Date: Mon, 2 Dec 2002 14:18:58 -0600
Subject: RE: Editing Crystal Form 5.1
Sorry. Tried that too. Do I ever have a mess this time!
Sent: Monday, December 02, 2002 2:00 PM
Subject: Re: [Vantage] Editing Crystal Form 5.1
Juliet,
(or however you spell it) folder). It is safe to go ahead and save the
report pointing to that location since Vantage will tell the report
where to look when the report is actually run from Vantage. The default
is usually c:\temp for the "Set Location" option.
Troy Funte
Liberty Electronics
started
but
Thanks!
Juliet
ADVERTISEMENT
Hope everyone had a great Thanksgiving! Hope that you all aren't too stuffed and can walk into work this morning! heehee!
Anyway.............I have an RB filter that requires 22 "compared to" values. It does not let me enter in all 22. It only lets me enter in up to 10. This is my current filter.
Unfortunately I need to add 12 more values to this list. These employee numbers have nothing else in common, so this is the only way I have been able to pull in only these employees so far. I also created an exact duplicate of this filter but used my next set of 12 values, but RB didn't like it. I have also tried using "not" for the filter, but I have more "not" values that I would have to enter in than my current filter setup.
Any ideas gang?
Wendy Bowen
Burton, Michigan
Wendy,
you could try,
1, 0)
limitation of RB.
Good Luck,
Wendy,
such as
OR
OR
Like this:
And
OR
And
OR
And
Shirley
Wendy,
you could try,
1, 0)
limitation of RB.
Good Luck,
ADVERTISEMENT
True, False)
-Todd C.
Any ideas gang?
Wendy Bowen
Burton, Michigan
ADVERTISEMENT
Do you mean that I should make these as calculations? Then make one final "test" calculation and make that the filter? I guess I'm not following exactly what you mean this morning. It's a Monday....heehee!
Wendy Bowen
Wendy,
you could try,
1, 0)
limitation of RB.
Good Luck,
ADVERTISEMENT
>current filter.
-Wayne Cox
828-685-2338
for us so far.
Nora Story
Patrick
for us so far.
Nora Story
