RB Question
thank you all
Sent: Wednesday, August 09, 2000 10:07 AM
To: 'vantage@egroups.com'
Subject: RE: [Vantage] RB Question
IIF(Value1 =0 and Value2 = 0,Whatever + 1," ")
Patrick J. Winter
Information Services Manager
sSc Specialty Screw Corporation
Vantage 3.00.614, Progress 8.3A
Sent: Wednesday, August 09, 2000 09:23 AM
It looks like i can use a case statement, but if i could im not sure how to
format. Basically i havbe to look at 5 fields if the value of all 5 are 0
then a variable is increased by 1
Sent: Wednesday, August 09, 2000 9:17 AM
To: Vantage (E-mail)
Subject: [Vantage] RB Question
Hello,
Need some help. Can you put multiple if statements in a calculation in
report builder. Doing a report for 4.0 a quote report and almost done. Just
need this bit of info. If you can could you post an example of the format.
Thanx
Can you just add the fields together? and then just use
one iif statement
--> iif(f1+f2+f3+f4+f5=0, x+1, x)
Tim Care
Electro Chemical Finishing
----- Original Message -----
To: <vantage@egroups.com>
Sent: Wednesday, August 09, 2000 10:22 AM
to
> From: Trzaska, Mark [mailto:mtrzaska@...]
> Hello,
Just
> Thanx
to
Groups,
above
to www.egroups.com, login and be sure to save your password, choose My
Groups, choose Vantage, then choose Files. If you save the password, the
link above will work the next time you try it.)
ill try it
Sent: Wednesday, August 09, 2000 10:02 AM
To: vantage@egroups.com
Subject: Re: [Vantage] RB Question
one iif statement
Tim Care
to
> Hello,
Just
> Thanx
to
Groups,
above
Patrick J. Winter
