# RB Sort help
**Category:** [Yahoo Archive](https://www.epiusers.help/c/yahoo-archive/9)
**Created:** 2000-08-03 13:03 UTC
**Views:** 406
**Replies:** 1
**URL:** https://www.epiusers.help/t/rb-sort-help/678
## Post #1 by @system
Jim, you need to change your Aggregate "Precentage" field from 'Final Pass'
processing to 'Pre-pass' processing.
Try this:
Select-->Calculations->Aggregate fields-->double-click your percentage
field. There is a button labeled "Options", click it and you will see a box
labeled Processing. Change the bullet to 'Pre-pass', click OK and Close.
This should do the trick.
Good luck
Jim Stetter
jsmith@...]
Sent: Thursday, August 03, 2000 12:50 PM
To:
vantage@egroups.com
Subject: [Vantage] RB Sort help
I have written a report to show customer backlog by percentage. It is
working the way it should and ties out to the numbers generated by the
canned backlog report, but I would like to sort the report by percentage.
When I try to do so I get the following "cannot sort or group on
final-pass-aggregate-related field. Any help would be appreciated.
Jim Smith
Lovejoy Chaplet Corporation
(518) 686-5232
## Post #2 by @system
Jim Smith
(518) 686-5232
**Canonical:** https://www.epiusers.help/t/rb-sort-help/678
**Original content:** https://www.epiusers.help/t/rb-sort-help/678
