RDD calc fields
Sadly, you've gotta have the SDK to play with those.
On Thu, Mar 1, 2012 at 5:09 PM, b_ordway <cooner_55421@...> wrote:
> As far as I know, Epicor hasn't exposed this to end users.
> For some reports, like Production Detail, I have found tech tips that
> explain the formulas used.
> --- In vantage@yahoogroups.com, "Anon" <jgiese@...> wrote:
> > How do RDD calculated fields work? To start with there is a native
> calculated field in the JobTrav RDD that I want to see how it is generated.
> Where do you see the logic used for these RDD Calc fields?
*John Driggers*
*High End Dev, System Design, Profit Drinking*
**:: 904.404.9233*
*:: waffqle@...*
*:: NO FAXES*
How do RDD calculated fields work? To start with there is a native calculated field in the JobTrav RDD that I want to see how it is generated. Where do you see the logic used for these RDD Calc fields?
For some reports, like Production Detail, I have found tech tips that explain the formulas used.
