RDD report with Criteria will not deploy to menu since 2024.1
Good job Valorie, glad you figured it out!
If you actually need to do a custom layer on your report though, for example, you want to do a slide out to run it from another screen, you have to generate form, then put it on the menu, then launch it from the menu, then go to application studio. Because there isn’t any other way to get there that I have been able to find. You shouldn’t have to go through all that and I don’t understand why they took away the direct link to application studio that used to show up when you clicked generate form.
Thanks for clarifying
