Hi Mike,
Sometimes yes I do use ODBC. However, more often I use Crystal against an
Access database. I use the Vantage Export function to create some "table dumps"
in dbf format from each of my divisions running Vantage. I then consolidate
these into a single Access database so that I can run Connor consolidated sales
reports.
We used to use ProVision to do something similar running RB against this
Progress Consolidated Sales Database. However, I wanted to simplify the process
(make it not reliant on ProVision programming skills) so that I could teach
non-programmers how to update / maintain this process...and I also wanted to
utilize Crystal with its enhanced feature set instead of RB.
A side benefit to using this Access database is that I have the flexibility to
add fields to these tables to make writing reports easier. This sometimes
negates the need to do certain joins or even utilize sub-reports.
But, the short answer to your original question is - sometimes.
Mike Lowe
Corporate I.S. Manager
Connor Manufacturing Services
MLowe@...
(909) 273-1282
____________________Reply Separator____________________
Subject: Re: Re[2]: [Vantage] RB - Top 25 Sales Results
Author: <vantage@yahoogroups.com>
Date: 1/14/2002 10:13 AM
Mike,
Do you use ODBC driver with Crystal Reports to access the information?
Mike Tonoyan / All American Products Co.
reports.
Mike Lowe
MLowe@...
(909) 273-1282
Mike,
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Friday, January 11, 2002 4:50 PM
Subject: Re[2]: [Vantage] RB - Top 25 Sales Results
> Mike,
> Guess I should have actually opened RB. I became curious and tried to get
this
> to work. Apparently the conditional printing doesn't work on an
aggregated
> grouped field. Sorry to lead you astray.
> This is one more reason to use Crystal. The TopN function is a built in
> function. A couple clicks and you would have exactly what you want.
> Crystal has a MUCH more robust function set. Well worth the investment in
money
> and time in training.
> My final 3 cents for the day...
> Mike Lowe
> Connor
> Subject: Re: [Vantage] RB - Top 25 Sales Results
> Date: 1/11/2002 3:35 PM
> Todd,
> I tried the way Mike Low and Ed advised, it didn't work for me.
> Do you have a sample report that you could e-mail to me?
> miket@...
> I'd appreciate it.
> From: "Todd Caughey" <caugheyt@...>
> Sent: Friday, January 11, 2002 2:11 PM
> Subject: RE: [Vantage] RB - Top 25 Sales Results
> > I do exactly this both for "Top n" as well as selecting for over/under
a
> > dollar or margin threshold. Works well. I don't count but rather Total
a
> > field set to 1 at a given group level. Then set a field to true or
false
> > dependingon if the count (or rank) is above the cuttoff. This used for
> the
> > conditional on the band line.
> > -Todd C.
> > -----Original Message-----
> > From: Mike Lowe [mailto:MLowe@...]
> > Sent: Friday, January 11, 2002 3:35 PM
> > To: vantage@yahoogroups.com; vantage@yahoogroups.com
> > Subject: Re:[Vantage] RB - Top 25 Sales Results
> > Ok, off the top of my head and not looking at Report Builder I think you
> can
> > create an aggregate field that will "count" group records. Place this
in
> > the
> > group line and use a conditional print to suppress printing for
everything
> > greater than 25. Or only print for everything 25 and less. Can't
> remember
> > which way the logic works.
> > Hope this helps...
> > Mike Lowe
> > Connor
> > Subject: [Vantage] RB - Top 25 Sales Results
> > Date: 1/11/2002 9:26 PM
> > Hello everyone,
> > I have a RB report that calculates and sorts the sales totals for the
> > distributors in descending order. It's for determining the top 25
> > distributors. Is there any way to print only top 25 customer totals
> > instead of the entire list?
> > Mike Tonoayn / MIS Manager
> > e-mail: miket@...
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> have
> > already linked your email address to a yahoo id to enable access. )
> > (1) To access the Files Section of our Yahoo!Group for Report Builder
and
> > Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.
> > <http://groups.yahoo.com/group/vantage/files/.>
> > http://groups.yahoo.com/group/vantage/messages
> > <http://groups.yahoo.com/group/vantage/messages>
> > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/links
> > <http://groups.yahoo.com/group/vantage/links>
> > Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
> > <http://docs.yahoo.com/info/terms/>
> > Yahoo! Groups Sponsor
> > ADVERTISEMENT
<http://rd.yahoo.com/M=216105.1806326.3318126.1261774/D=egroupweb/S=17050071
83:HM/A=915130/R=0/O=1/I=brandr-lrec/postholidaygroup/*http://shopping.yahoo
> > .com/domain?d=holiday&cf=posthol01>
<http://us.adserver.yahoo.com/l?M=216105.1806326.3318126.1261774/D=egroupmai
> > l/S=1705007183:HM/A=915130/rand=793693474>
> have
and
> > Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service
> > <http://docs.yahoo.com/info/terms/> .
> have already linked your email address to a yahoo id to enable access. )
and
have
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
