Now I remember.... If you do a complete regen it does pick it up
but the net change won't.
> Are you sure, when I tested this in early access it did. MRP deletes all
> unfirm jobs.(Your case the old revision), It then consumes the forecast and
> creates new jobs to meet this. (In your case grabbing the new revision) You
> may need to unapprove the old revision, I'm not sure. The only down side I
> found is that it will eat up job numbers because if it creates a 1000 jobs
> and you firm up job 900, when it deletes unfirm and starts creating again it
> starts at 901 and does'nt reuse 1-900.
> Patrick J. Winter
> Information Services Manager
> sSc Specialty Screw Corporation
> -----Original Message-----
> From: Joe Konecny [mailto:jkonecn@...]
> Sent: Thursday, July 27, 2000 08:09 AM
> To: vantage@egroups.com
> Subject: Re: [Vantage] RE: Call Number 583663MPS Technical Support
> Reply: JM - Mass ABOM replace
> Our testing has shown this doesn't work. It apparently does
> not look at BOM/routing changes, only sales order/forecast/
> mps changes.
> > The MRP module will do this for you on jobs that are unfirm.
> > (Remove the old job and create a new one with the latest rev.)
> > This is perfect for work center, work center rate changes, any updates to
> > part routings.
> We no longer allow attachments to files. To access/share Report Files, please go to the following link: http://www.egroups.com/files/vantage/
> (Note: If this link does not work for you the first time you try it, go to www.egroups.com, login and be sure to save your password, choose My Groups, choose Vantage, then choose Files. If you save the password, the link above will work the next time you try it.)
