Read-Only Menu Items Not Read-Only
8.03.405.
I added Company Maintenance as a read-only menu item under Finance/GL
so folks there could see the control accounts setup in the Company.
Despite the fact that the Save button is disabled and the form is
otherwise read-only, the radio-button controls on the form are
clickable/changeable, and it is possible to change the GL account format
and default costing method. When you close the form, you're prompted to
save. I did this by mistake (and then quickly undid it!).
Am I on crack?
I opened a case on this with Support.
-bws
Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix /
Picometrix
bspolarich@...
<mailto:bspolarich@...> ~ 734-864-5618 ~
www.advancedphotonix.com <http://www.advancedphotonix.com>
