Yes it was very helpfull, do you know more of session variables?
Grzegorz Szczepanski
Dnia Tue, 5 Aug 2008 18:22:15 +0100
> These are some you can use in 4GL code.
> DCD-USERID
> CUR-PLANT
> CUR-COMP
> Hope this helps.
> Regards,
> Stephen
> Behalf Of Robert Brown Sent: 05 August 2008 17:36
> To: vantage@yahoogroups.com
> Subject: Re: [Vantage] Reading the database in VB .NET
> Grzegorz,
> Nice work! That is some fine coding for someone who (in your origianl
> email) left the impression of being somewhat unfamiliar with .NET
> coding.
> While you clearly took a different path than my example, it looks
> like a much stronger process as a result. (Glad my lengthy email was
> of any help.)
> I'm new to BPM myself and would likely do you a disservice on how to
> detect the userID via 4GL. I would only recommended 2 things:
> (1) Set up a full detail trace and then Open the invoice app (and do
> nothing else). Open the trace log and do a text find/search on your
> userID. I'd be shocked if that doesn't lead you to trace sections
> that invoked BO methods (that expose the userID) that you can trap
> via 4GL.
> (2) "Ask Wonsil". Mark Wonsil (as well as several other regulars in
> the user group) are absolute whizzes at BPM/4GL.
> Rob Brown
> --- On Tue, 8/5/08, phoenix <phoenix_@... <mailto:phoenix_%40wp.pl>
> > wrote:
> From: phoenix <phoenix_@... <mailto:phoenix_%40wp.pl> >
> Date: Tuesday, August 5, 2008, 5:00 AM
> Robert,
> Thank you for your answer, it was very helpfull.
> I have developed my own resolution, which basically force "save"
> action, each time when user is clicking particular field. So my code
> is like below:
> (I am tracking changes to PayHold and InvoiceHeld)
> BTW Do you know how can I obtain a session variables in 4GL - like
> Session.UserID, Session.UserName?
> *****c o d e*****
> Private Sub APInvHed_AfterField Change(ByVal sender As object, ByVal
> args As DataColumnChangeEve ntArgs) Handles APInvHed_Column.
> ColumnChanged '// ** Argument Properties and Uses ** '//
> args.Row("[FieldNam e]") '// args.Column, args.ProposedValue, args.Row
> 'Add Event Handler Code
> Dim sUserIdent As String = APInvoiceForm. Session.UserID
> Dim sNazwaUzyt As String = APInvoiceForm. Session.UserName
> Dim sCzasData As String
> If bZmiana = TRUE then
> PayHold = Ctype(csm.GetNative ControlReference ("13285910- 6101-4aab-
> 9526-e8cd723b621 b"),EpiCheckBox) InvoiceHeld = Ctype(csm.GetNative
> ControlReference ("e474fa10- 0be5-43b4- 9814-4a349805d1b
> f"),EpiCheckBox) Select Case args.Column. ColumnName
> Case "InvoiceHeld"
> If InvoiceHeld. Checked = False then
> If MessageBox.Show( "Czy akceptujesz tê faktury? ","Akceptacja
> faktury", MessageBoxButtons. OKCancel, _ Nothing, MessageBoxDefaultBu
> tton.Button1) = DialogResult. OK Then 'PayHold.Text = "Ze stanu
> zaznaczony wybra³e OK" & chr(13) & _ '"Teraz przycisk powinien byæ
> odznaczony" & chr(13) & _ 'sUserIdent & chr(13) & Now()
> sCzasData = Now()
> InvoiceHeld. Text = sNazwaUzyt & chr(13) & chr(13) & _
> "Zaakceptowa³ e fakturê" & chr(13) & _
> "numer: " & args.Row("InvoiceNu m") & chr(13) & chr(13) & sCzasData
> MessageBox.Show( InvoiceHeld. Text,"Faktura zaakceptowana" )
> args.Row("Character 04") = args.Row("Character 04") & sUserIdent &
> ";" & sCzasData _ & ";" & "Akceptacja" & chr(13)
> oTrans.Update( 1)
> Else
> bZmiana = FALSE
> 'PayHold.Text = "Ze stanu zaznaczony wybra³e Anuluj" & chr(13) & _
> '"Teraz przycisk powinien byæ zaznaczony" & chr(13) & _
> 'sUserIdent & chr(13)& Now()
> InvoiceHeld. Text = "Zrezygnowa³e z akceptacji faktury," & chr(13) & _
> "faktura pozostaje nadal niezaakceptowana"
> MessageBox.Show( InvoiceHeld. Text,"Rezeygnacj a z akceptacji")
> args.Row("InvoiceHe ld")=TRUE
> End If
> Else
> If MessageBox.Show( "Czy chcesz wstrzymaæ tê fakturê? ","Wstrzymanie
> odznaczony wybra³e OK" & chr(13) & _ '"Teraz przycisk powinien byæ
> zaznaczony" & chr(13) & _ 'sUserIdent & chr(13) & Now()
> sCzasData = Now()
> "Wstrzyma³e fakturê" & chr(13) & _
> MessageBox.Show( InvoiceHeld. Text,"Faktura wstrzymana")
> ";" & sCzasData _ & ";" & "Wstrzymanie" & chr(13)
> oTrans.Update( 1)
> Else
> bZmiana = FALSE
> 'PayHold.Text = "Ze stanu odznaczony wybra³e Anuluj" & chr(13) & _
> '"Teraz przycisk powinien byæ odznaczony" & chr(13) & _
> InvoiceHeld. Text = "Zrezygnowa³e ze wstrzymania faktury," & chr(13)
> & _ "faktura pozostaje nadal zaakceptowana"
> MessageBox.Show( InvoiceHeld. Text,"Rezeygnacj a ze wstrzymania" )
> args.Row("InvoiceHe ld")=FALSE
> End If
> End if
> bZmiana = TRUE
> Case "PayHold"
> If PayHold.Checked = False then
> If MessageBox.Show( "Czy akceptujesz p³atnoæ dla tej faktury?
> ","Akceptacja p³atnoci", MessageBoxButtons. OKCancel, _ Nothing,
> MessageBoxDefaultBu tton.Button1) = DialogResult. OK Then
> 'PayHold.Text = "Ze stanu zaznaczony wybra³e OK" & chr(13) & _
> '"Teraz przycisk powinien byæ odznaczony" & chr(13) & _ 'sUserIdent &
> chr(13) & Now() sCzasData = Now()
> PayHold.Text = sNazwaUzyt & chr(13) & chr(13) & _
> "Zaakceptowa³ e p³atnoæ dla faktury" & chr(13) & _
> MessageBox.Show( PayHold.Text, "P³atnoæ zaakceptowana" )
> args.Row("Character 03") = args.Row("Character 03") & sUserIdent &
> oTrans.Update( 1)
> Else
> bZmiana = FALSE
> PayHold.Text = "Zrezygnowa³e z akceptacji p³atnoci," & chr(13) & _
> "p³atnoæ pozostaje nadal wstrzymana"
> MessageBox.Show( PayHold.Text, "Rezeygnacja z akceptacji")
> args.Row("PayHold" )=TRUE
> End If
> Else
> If MessageBox.Show( "Czy chcesz wstrzymaæ p³atnoæ dla tej faktury?
> ","Wstrzymanie p³atnoci", MessageBoxButtons. OKCancel, _ Nothing,
> 'PayHold.Text = "Ze stanu odznaczony wybra³e OK" & chr(13) & _
> '"Teraz przycisk powinien byæ zaznaczony" & chr(13) & _ 'sUserIdent &
> "Wstrzyma³e p³atnoæ dla faktury" & chr(13) & _
> MessageBox.Show( PayHold.Text, "P³atnoæ wstrzymana")
> oTrans.Update( 1)
> Else
> bZmiana = FALSE
> PayHold.Text = "Zrezygnowa³e ze wstrzymania p³atnoci," & chr(13) & _
> "p³atnoæ pozostaje nadal zaakceptowana"
> MessageBox.Show( PayHold.Text, "Rezeygnacja ze wstrzymania" )
> args.Row("PayHold" )=FALSE
> End If
> End if
> bZmiana = TRUE
> Case Else
> End Select
> End If 'bZmiana
> End Sub
> *****e n d o f c o d e*****
> Grzegorz Szczepañski
> Dnia Sat, 26 Jul 2008 09:51:50 -0700 (PDT)
> Robert Brown <robertb_versa@ yahoo.com> napisał(a):
> > I agree change log and auditing aren't perfect - but I've never seen
> > them NOT work. I've just seen instances where the logging was set up
> > against the wrong table.field.
> > MUCH too easy to do as most apps have views that are redundant in
> > many (field) aspects - as they serve different app purposes - and
> > don't represent 'true' tables as defined in the data dictionary. If
> > you enable full tracing & mimic the action(s) in the app you wish to
> > capture activity history against, the 'true' table.field( s) being
> > updated (that you wish to set up for change log tracking or
> > auditing) will be revealed.
> > Also, since (after re-reading your original post) it appears you are
> > trying to capture not actual written to db changes - but also user
> > actions creating a pending change that is then rejected and not
> > written to the db - you have left yourself with a very challenging
> > problem. (Why you want to track entered but rejected update actions
> > is beyond me - but that is your problem to justify).
> > Let's assume you've thoroughly done that though and you are still
> > not getting what you want (eliminating the built in mechanisms as
> > possible solutions).
> > That is likely because you are attempting to capture pending changes
> > that have a messagebox.show( "Y"/"N") (or 4GL equivalent) UI
> > selection interrupt within the BO/method "Update" routine that
> > either results in proceeding with or aborting the Update. Unless
> > Tracing shows otherwise, that is likely a 'black box' compiled code
> > UI object/method that offers no simple way to trap it and write the
> > results to your custom log.
> > You'll have to get devious in order to accomplish what you want
> > (and, I warn you, the complexity of the customization will impact
> > perceived application responsiveness) . Being an Invoice app, it
> > hopefully won't be enough to thoroughly annoy users (as many
> > Vantage BASE apps are already painfully slow) and impact their
> > productivity.
> > I assume you already already have Function code to capture the
> > current userID (on application load) and the current system
> > date/time every time an action you want to log occurs AND you've
> > assigned them some simple aliases (Ex.,: "cUserID" containing the
> > UserID value you captured on load and "cDateTime() " being a
> > callable function to get the exact current date/time as needed)
> > For every native checkbox control you wish to track, create a custom
> > textbox linked to the same table/field. (Once you know your
> > customization is working, make them not-visible and, for good
> > measure, slide them off into a negative panel coordinate position -
> > as even 'not visible' controls sometimes bleed through and appear on
> > the screen - creating distractions to users.)
> > Let's call these custom textboxes txtChk1, txtChk2, etc., for the
> > example.
> > Because they are linked to boolean fields, they will either contain
> > null text values (if no Invoice record is loaded - a state
> > equivalent to having no record loaded in the app: "row= -1"),
> > "TRUE" (when the native checkbox is checked) or "FALSE" (when the
> > native checkbox is unchecked).
> > Now, use your wizard to set up the shell of Subs for each custom
> > checkbox that will be triggered when _ChangedValue.
> > At the module level, Dim a public text variable ("MyLog" for this
> > example).
> > Also set up the necessary Private WithEvents declaration of your
> > dataview alias that contains the UD character field you are storing
> > your change log data in. Don't forget to add the code to initialize
> > it and enable read/write to it (and also destroy it when the app
> > closes).
> > Let's assign this dataview(field) - field being the specific UD
> > character field holding your log record - an alias "MyLogViewVal" .
> > Then, within each wizard generated Sub, add an If loop:
> > If len(txtChk1. text) <> 0 Then
> > End If
> > This will prevent your code from generating errors when clearing the
> > app of a record.
> > It is within each of these If loops that you will then add your code
> > to APPEND your change log record.
> > 'Capture the current value of your change log record and start
> > 'appending it.
> > MyLog = (MyLogViewVal & " ; " & cUserID & " " & cDateTime()
> > & _" txtChk1 value set to " & txtChk1.text)
> > 'Now write back the appended info ONLY to the specific
> > 'table.udCharfield record where you are storing the log
> > '- NOT updating the entire table (or, worse yet, all tables in
> > the 'app)!
> > MyLogViewVal = MyLog
> > ' You may or may not need this:
> > otrans.update( MyLogViewVal)
> > End If
> > Doing this within every Sub triggered by your custom txtChk# control
> > value changes will capture the interrum user changes BEFORE they are
> > written to the db.
> > The last step is to determine (via tracing) what business object
> > adapter (& methods) are used to prompt the user to accept (& update
> > the db) or reject (and return the value(s) to their original state).
> > Use your wizard again to trap the adapter (probably after_method)
> > and set up Cases that are invoked either after the user accepts the
> > pending changes and updates the db or rejects them.
> > Within those two cases, once again insert code similar to above:
> > Case "someMethod"
> > 'Whatever the method name is for Updating
> > 'and a second Case method for rejection of changes
> > MyLog = (MyLogViewVal & " ; Updated " & " " & cDateTime()
> > & _" Updated ")
> > ' replace " Updated " with something like " ChangeAborted "
> > ' with the Case "someMethod" invoked for rejecting the change.
> > ' Again - You may or may not need this:
> > Not pretty - but it should work with proper code tweaks.
> > My sympathies to you for whoever feels this is level of auditing is
> > needed.
> > (Good training and management can't be replaced by heavy handed "big
> > brother is watching you" applications. )
> > Rob Brown
> > --- On Sat, 7/26/08, phoenix <phoenix_@wp. pl> wrote:
> > From: phoenix <phoenix_@wp. pl>
> > To: vantage@yahoogroups .com
> > Date: Saturday, July 26, 2008, 3:30 AM
> > Robert,
> > Several people already prove that change log is not always working.
> > So I decided to have my own change log on this particular fields
> > toogether with two text boxes on separeate sheet that are showing
> > the changes.
> > I found that after the form is open I Just need a simple thing
> > Row.args("NameofFie ld") = Row.args("NameofFie ld") & "text to be
> > added"
> > Now I Need to :
> > 1. Find a way to refresh this text boxes each time the user is
> > clicking on the tab of this sheet - any suggestions?
> > 2. Find a way to force SAVE action, oTrans.Update is not working
> > with some reasons. Maybe because I need to add some information
> > witch view a want to save?
> > Grzegorz Szczepański
> > Dnia Fri, 25 Jul :59: (PDT)
> > > Why not just utilize some combo of the built in change & audit
> > > logging?
> > > Subject: [Vantage] Reading the database in VB .NET
> > > Date: Friday, July 25, 2008, 3:54 AM
> > > I need to read some data from database using vb .net, can anyone
> > > help with that?
> > > The scenario is like following:
> > > I am tracking the changes that user is doing on some checkboxes
> > > within invoice entry. Each time when user is clicking this
> > > checkbox a message box is displayed with possibility to accept or
> > > reject the changes. All the above is done, now I need to: use a
> > > character field to write there some data about time and userid,
> > > like
> > > :01.01 Accepted John Doe
> > > :01.05 Rejected John Doe
> > > and this is also not a problem,
> > > I know how to update a character field within the dataset,
> > > But before applaying the changes I need to read the content of
> > > this filed in database and then ADD my changes, ( DO NOT replace
> > > it.)
> > > Any help with code reading the context of database?
