we are having a heck of a time trying to figure out the history on a transaction for a PO Receipt for 1 Receipt Line.
If anyone could point me in the right direction, it would be appreciated to understanding the dates in general with the PO receipt process. Thanks
Pete
RcvHead_RecDate - Setting this prompts to set the RcvDtl_RecDate to that date for all lines on the pack. You can say no, and then this date means nothing.
RcvDtl_RecDate - the line receipt date, which should match PartTran and TranGLC Tran Dates. This is the date the receipt transactions transact on.
PartTran SysDate is the actual/physical day the transaction was created on.
TranGLC CreateDate is the date the GL Transaction was created, typically by running the capture process
