Receipt Entry - Prevent receipt date prior to today()
Doing it in that screen in particular won’t stop other screens or processes from doing it however. So if you folks utilize the handheld module or MES you will need to update all of them, along with all the ones launched by Process Calling.
Joshua Giese
Technology Solutions : CTO
Direct Phone:    920.593.8299
Office Phone:    920.437.6400 x342
http://wcibags.com/email/emailFooter4.jpg
http://68c6d48672d1935cd6dd-141aaade86a30aeaf83cb6aee3728aaa.r82.cf1.rackcdn.com/images/global/Holiday-Schedule-2015.jpg
Sent: Thursday, December 3, 2015 1:43 PM
Subject: RE: [Vantage] Receipt Entry - Prevent receipt date prior to today()
Yeah.
It's working now.
Turns out that the unable to update the receipt was caused by another factor.  The VBScript code is what I'm using right in a customization of the Receipt Entry form.  I could not successfully apply a condition based of the Date(Today) variable in ABL.
Thanks!
Hello everybody!
I'm trying to prevent users from creating a receipt with a receipt date prior to today.
I created a BPM, but was unable to use the wizard to throw an exception with a variable of today() in ABL, I can create an exception, but it requires an actual date and won't except a variable.
I then created an if statement to throw an exception or message if the date is before today() as in:
Private Sub RcvHead_AfterFieldChange(ByVal sender As object, ByVal args As DataColumnChangeEventArgs) Handles RcvHead_Column.ColumnChanged
'// ** Argument Properties and Uses **
'// args.Row("[FieldName]")
'// args.Column, args.ProposedValue, args.Row
'Add Event Handler Code
Dim [edvVarName] As EpiDataView = CType(oTrans.EpiDataViews("RcvHead"), EpiDataView)
Dim [VarName] As DateTime = [edvVarName].dataView([edvVarName].Row)("ReceiptDate")
Dim myDate As Date
myDate = DateValue(Now)
Select Case args.Column.ColumnName
Case Else
                if ([varname] < mydate)
                throw new exception("Invalid date")
                end if
End Select
End Sub
The previous throws the exception, but returns that it cannot update the Receipt Date field, even if the date doesn't throw an exception.
I'm still running 8.03.410
This should work as a BPM? You said you can get the exception as a BPM but then I didn’t fully follow the part that wasn’t working
Joshua Giese
Sent: Thursday, December 3, 2015 11:01 AM
Subject: [Vantage] Receipt Entry - Prevent receipt date prior to today()
Hello everybody!
Dim myDate As Date
                                    Case Else
                end if
                        End Select
            End Sub
It could be a date format issue...
Sent from my iPhone
On Dec 3, 2015, at 12:03 PM, Joshua Giese jgiese@... [vantage] <vantage@yahoogroups.com> wrote:
Joshua Giese
Hello everybody!
Dim myDate As Date
                                    Case Else
                end if
                        End Select
            End Sub
Here's the BPM condition:
the RcvHead.ReceiptDate field of the changed row is less than the Date(12,01,2015) value
the problem is the date needs to be a variable function of today().  I've created a variable in advanced and assigned to today(), but it still wants the literal date.
Dates are always a big pain.  Try putting the value(s) you are using into a popup to see what format is actually coming up.
In ABL you just need “TODAY”
These are E9 examples if they help.
set the Part.Date01 field of the changed row to the  Today expression
ASSIGN JobOper.Number03 = (IF (JobHead.Date01 = TODAY) THEN (1) ELSE (0)).
Brenda
Sent: Thursday, December 03, 2015 12:01 PM
Hello everybody!
Dim myDate As Date
                                    Case Else
                end if
                        End Select
            End Sub
The variable is TODAY not TODAY() if you are using it as such you are going to have trouble. Using TODAY in the expression for the condition should be working post a screenshot of it on imgur or something as exactly what you have. So we can take a look.
Joshua Giese
Sent: Thursday, December 3, 2015 11:19 AM
Subject: Re: [Vantage] Receipt Entry - Prevent receipt date prior to today()
Yeah.
It's working now.
Thanks!
