Receipt Entry - Release Due Date
Hi,
Thanks that is brilliant you are a star... Really got me out of a
hole and will help on other issues.
Thanks again and again.
--- In vantage@yahoogroups.com, "bw2868bond" <bwalker@...> wrote:
> Try this:
> Module Script
> '// ** Wizard Insert Location - Do Not Remove 'Begin/End
> Wizard Added Module Level Variables' Comments! **
> '// Begin Wizard Added Module Level Variables **
> Private WithEvents edvPendingRcvDtl As EpiDataView
> Private DidThat As Boolean
> Private WithEvents oTrans_receiptAdapter As EpiBaseAdapter
> '// End Wizard Added Module Level Variables **
> '// Add Custom Module Level Variables Here **
> Sub InitializeCustomCode()
> '// ** Wizard Insert Location - Do not
> delete 'Begin/End Wizard Added Variable Intialization' lines **
> '// Begin Wizard Added Variable Intialization
> oTrans_receiptAdapter = csm.TransAdaptersHT
> ("oTrans_receiptAdapter")
> '// End Wizard Added Variable Intialization
> '// Begin Custom Method Calls
> DidThat = False
> edvPendingRcvDtl = CType(oTrans.EpiDataViews
> ("PendingRcvDtl"), EpiDataView)
> Dim edvPending As EpiDataView = CType(oTrans.EpiDataViews
> If Not (edvPending.dataView.Table.Columns.Contains
("DueDate"))
> edvPending.dataView.Table.Columns.Add(new DataColumn
> ("DueDate"))
> End If
> '// End Custom Method Calls
> End Sub
> Sub DestroyCustomCode()
> delete 'Begin/End Wizard Added Object Disposal' lines **
> '// Begin Wizard Added Object Disposal
> oTrans_receiptAdapter = Nothing
> '// End Wizard Added Object Disposal
> '// Begin Custom Code Disposal
> '// End Custom Code Disposal
> End Sub
> Private Function getDueDate(ByVal po as Integer, ByVal line as
> Integer, ByVal rel as Integer ) As String
> Dim dueDate As String
> Dim recordSelectedRel As Boolean
> Dim showSearch As Boolean = False
> Dim whereClauseRel As String = "PONum = '" & po & "' And
> POLine = '" & line & "' And PORelNum = '" & rel & "'"
> Dim dsRelease As DataSet = SearchFunctions.listLookup
> (ReceiptEntryForm, "PORelSearchAdapter", recordSelectedRel,
> showSearch, whereClauseRel)
> If (recordSelectedRel = True) Then
> dueDate = dsRelease.Tables(0).Rows(0)
> ("DueDate").ToShortDateString()
> End If
> Return dueDate
> End Function
> Private Sub AddDueDate()
> '//Add additional get the Due dates for the Released and
add
> more columns....
("DueDate"))
> ("DueDate"))
> End If
> '//Add the Value into the Rows
> For Each dr As DataRow in edvPending.dataView.Table.Rows
> If IsDBNull(dr("DueDate")) Then
> dr("DueDate") = getDueDate(dr("PONum"),dr
("POLine"),dr
> ("PORel"))
> End If
> Next
> End Sub
> Private Sub edvPendingRcvDtl_EpiViewNotification(view As
> EpiDataView, args As EpiNotifyArgs) Handles
> edvPendingRcvDtl.EpiViewNotification
> If (args.NotifyType =
> EpiTransaction.NotifyType.Initialize) Then
> If (args.Row > -1) And (DidThat = False) Then
> AddDueDate()
> DidThat = True
> End If
> If (args.Row = -1) Then
> DidThat = False
> End If
> End If
> End Sub
> Private Sub oTrans_receiptAdapter_AfterAdapterMethod(ByVal
> sender As object, ByVal args As AfterAdapterMethodArgs) Handles
> oTrans_receiptAdapter.AfterAdapterMethod
> '// ** Argument Properties and Uses **
> '// args.MethodName
> 'Add Event Handler Code
> 'MessageBox.Show(args.MethodName) ' use this to find
> method
> Select Case args.MethodName
> Case "Update"
> DidThat = False
> Case Else
> End Select
> End Sub
> End Module
> We have a lot more going on in our customization which I cut out -
I
> may have removed something needed for the due date by accident...
> --- In vantage@yahoogroups.com, "brychanwilliams"
> <brychanwilliams@> wrote:
> > Hi,
> > I have been trying to do this myself, I get the list to display
by
> > creating a dataview and applying the filter but it is not passing
> the
> > correct rows across. Maybe it is still referring to a the
original
> > dataview in the background? Did you manage to solve this one? If
> so,
> > any advice or direction which would be helpful?
> > Thanks
> > --- In vantage@yahoogroups.com, "Gary Parfrey" <garyp@> wrote:
> > > Bernie
> > > No its only available on the Received tab, not the pending
> receipt
> > tab.
> > > Crazy as you can only check what you have booked in incorrectly!
> > > This is in our own list of pending screen customizations
> > > Gary Parfrey
> > > Dot Net IT Limited, Reg No 4412519
> > > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]
On
> > Behalf
> > > Of bw2868bond
> > > Sent: 02 August 2007 13:29
> > > To: vantage@yahoogroups.com
> > > Subject: [Vantage] Receipt Entry - Release Due Date
> > > Do any of the 8.03.4xx Beta testers know if the PO Line Release
> > DueDate
> > > is a field available for display on the Receipt Entry pending
> > receipts
> > > grid?
> > > It is not available in 8.00 or 8.03.305. It seems like it would
> be
> > a
> > > nice bit of data to have for display when there are multiple
> > releases
> > > for a part and the dates may have gotten jumbled by PO
> > maintenance....
> > > The DueDate field is fundamentally lacking in the GetPendingDtl
> > Method
> > > so a quick and dirty customization doesn't look promising..
> > > Thanks,
> > > Bernie.
Do any of the 8.03.4xx Beta testers know if the PO Line Release DueDate
is a field available for display on the Receipt Entry pending receipts
grid?
It is not available in 8.00 or 8.03.305. It seems like it would be a
nice bit of data to have for display when there are multiple releases
for a part and the dates may have gotten jumbled by PO maintenance....
The DueDate field is fundamentally lacking in the GetPendingDtl Method
Bernie.
Bernie
No its only available on the Received tab, not the pending receipt tab.
Gary Parfrey
Of bw2868bond
grid?
Bernie.
Hi,
I have been trying to do this myself, I get the list to display by
creating a dataview and applying the filter but it is not passing the
correct rows across. Maybe it is still referring to a the original
dataview in the background? Did you manage to solve this one? If so,
--- In vantage@yahoogroups.com, "Gary Parfrey" <garyp@...> wrote:
> Bernie
tab.
> Gary Parfrey
Behalf
> Of bw2868bond
DueDate
receipts
> grid?
a
releases
maintenance....
Method
> Thanks,
> Bernie.
Try this:
Module Script
DidThat = False
If Not (edvPending.dataView.Table.Columns.Contains("DueDate"))
("DueDate"))
End If
End Sub
End Sub
End If
Return dueDate
End Function
'//Add additional get the Due dates for the Released and add
more columns....
("DueDate"))
End If
dr("DueDate") = getDueDate(dr("PONum"),dr("POLine"),dr
("PORel"))
End If
Next
End Sub
AddDueDate()
DidThat = True
End If
DidThat = False
End If
End If
End Sub
'// args.MethodName
method
Case "Update"
DidThat = False
Case Else
End Select
End Sub
End Module
We have a lot more going on in our customization which I cut out - I
<brychanwilliams@...> wrote:
> Hi,
the
so,
> Thanks
> > Bernie
receipt
> tab.
> > Gary Parfrey
> Behalf
> > Of bw2868bond
> DueDate
> receipts
> > grid?
be
> a
> releases
> maintenance....
> Method
> > Thanks,
> > Bernie.
