Receipt Not Invoiced (8.03.403D)
I do understand what you are saying....
Manasa
630.806.2000 x1515
Of Kevin Simon
Sent: Wednesday, January 19, 2011 3:06 PM
Subject: RE: [Vantage] Receipt Not Invoiced (8.03.403D)
My experience with custom programming has been that by the time you wait
the
six weeks to actually talk to someone, then have to write up the specs,
wait
for them to return their design, go back through and correct them on it,
test what they gave you and figure out it solves a problem, just not
your
problem, etc, etc, etc.
You end up spending $2000 of your time to pay them $4000 for something
you
could've done for $500 yourself.
Behalf Of
Manasa Reddy
Sent: Wednesday, January 19, 2011 2:54 PM
Sorry Kevin,
The point was that if YOU were too busy to do it, then having custom
programming do it for you is not a big deal. For what this guy wants it
should not cost more than $1200 or so...it is a simple program in terms
of what he wants done. But then Epicor has it standards and I am sure
it is more now than it was 5 years ago!
Manasa
630.806.2000 x1515
Behalf
Of Kevin Simon
Sent: Wednesday, January 19, 2011 1:49 PM
$500 for a program from Custom Programming? Can I have the name of your
sales rep please - I'm going through them from now on!!
Kevin
Behalf Of
Manasa Reddy
Sent: Wednesday, January 19, 2011 2:25 PM
Unless you are a programmer, I'd bite the bullet, pay about $500 for a
program from Epicor to close these all out!
Or maybe someone on this list has something like this already and can
help out...
Manasa
630.806.2000 x1515
Behalf
Of to.crds
Sent: Wednesday, January 19, 2011 1:02 PM
Subject: [Vantage] Receipt Not Invoiced (8.03.403D)
I've seen a couple of threads about clearing up 'Received Not Invoiced'
receipts, but the solutions(create a $0.00 invoice) seem to be for the
occasional cleanup.
I've got the problem where receipts go back for years (and from versions
back as far as Vista 4), and number at about 15,000.
Is there a way to force those recipts to be marked as Invoiced, (without
creating a storm of GL transactions), without having to go into each
one, one at a time?
In the past I've "tweaked" the databases (using MS Access with a R/W
link to tables), but this makes me shudder (as most of you are probably
doing right now). Any way to do a "where used" for a field in table?
Thanks in advance,
Calvin
I've seen a couple of threads about clearing up 'Received Not Invoiced' receipts, but the solutions(create a $0.00 invoice) seem to be for the occasional cleanup.
I've got the problem where receipts go back for years (and from versions back as far as Vista 4), and number at about 15,000.
Is there a way to force those recipts to be marked as Invoiced, (without creating a storm of GL transactions), without having to go into each one, one at a time?
In the past I've "tweaked" the databases (using MS Access with a R/W link to tables), but this makes me shudder (as most of you are probably doing right now). Any way to do a "where used" for a field in table?
Thanks in advance,
Calvin
help out...
Manasa
630.806.2000 x1515
Of to.crds
occasional cleanup.
one, one at a time?
Thanks in advance,
Calvin
I am a programmer (at least I pretend to be), but my time (and worry) would quickly add up to $500.
But as an academic question, Is there any way to determine the dependencies on a field throught the system?
We all know some fields are benign (OrderDet.Char01, doesn't trigger anything, unless you've added customizations), but what finding out the others?
> help out...
> Manasa
> 630.806.2000 x1515
> Of to.crds
> occasional cleanup.
> one, one at a time?
> Thanks in advance,
> Calvin
Do you know about the data dictionary? It's under System Management.
This will tell you all of the fields that are in all of the tables in
the database you are using.
Is this what you are looking for?
Manasa
630.806.2000 x1515
Of to.crds
Sent: Wednesday, January 19, 2011 1:36 PM
Subject: [Vantage] Re: Receipt Not Invoiced (8.03.403D)
others?
> help out...
> Manasa
> 630.806.2000 x1515
Behalf
> Of to.crds
Invoiced'
> occasional cleanup.
versions
(without
> one, one at a time?
probably
> Thanks in advance,
> Calvin
There is also dataset relationships, but this only gives relationship
dependencies on some tables, not all.
Manasa
630.806.2000 x1515
Of Manasa Reddy
Sent: Wednesday, January 19, 2011 1:40 PM
Subject: RE: [Vantage] Re: Receipt Not Invoiced (8.03.403D)
Manasa
630.806.2000 x1515
Behalf
Of to.crds
others?
> help out...
> Manasa
> 630.806.2000 x1515
Behalf
> Of to.crds
Invoiced'
> occasional cleanup.
versions
(without
> one, one at a time?
probably
> Thanks in advance,
> Calvin
I'm famailiar with the Data dictionaries. I'm looking to findout where a field is referenced by other tables, or processes.
Usually when a field is R/O for all data views, that means the system wants exclusive control, and it's either changed by specific processes, or changing it triggers other processes.
Calvin
> Manasa
> 630.806.2000 x1515
> Of to.crds
> others?
> > help out...
> > Manasa
> > 630.806.2000 x1515
> Behalf
> > Of to.crds
> Invoiced'
> > occasional cleanup.
> versions
> (without
> > one, one at a time?
> probably
> > Thanks in advance,
> > Calvin
Kevin
Manasa Reddy
help out...
Manasa
630.806.2000 x1515
Behalf
Of to.crds
occasional cleanup.
one, one at a time?
Thanks in advance,
Calvin
Sorry Kevin,
Manasa
630.806.2000 x1515
Of Kevin Simon
Kevin
Behalf Of
Manasa Reddy
help out...
Manasa
630.806.2000 x1515
Behalf
Of to.crds
occasional cleanup.
one, one at a time?
Thanks in advance,
Calvin
Yep, I'm the wrong person to ask...I'm sure someone else WILL answer
your question eventually!
Good luck!
Manasa
630.806.2000 x1515
Of to.crds
Sent: Wednesday, January 19, 2011 1:48 PM
Calvin
> Manasa
> 630.806.2000 x1515
Behalf
> Of to.crds
the
> others?
a
can
> > help out...
> > Manasa
> > 630.806.2000 x1515
> Behalf
> > Of to.crds
> Invoiced'
the
> > occasional cleanup.
> versions
> (without
> > one, one at a time?
> probably
> > Thanks in advance,
> > Calvin
I am not sure what your question is.
RcvHead.Invoiced and RcvDtl.Invoiced are the flags that mark a receipt as invoiced or not.
As for a where-used for a field name, the following progress code will tell you where a particular field name is used (in this case, the field name is systemabc. That tells you which tables have a field with that name. I don't know if you have a progress editor, but there is an equivalent command in sql to read the metaschema.
FOR EACH _field
WHERE _field._field-name = "systemabc",
EACH _file OF _field:
DISPLAY _file._file-name.
END.
> Thanks in advance,
> Calvin
My experience with custom programming has been that by the time you wait the
six weeks to actually talk to someone, then have to write up the specs, wait
test what they gave you and figure out it solves a problem, just not your
You end up spending $2000 of your time to pay them $4000 for something you
Manasa Reddy
Sorry Kevin,
Manasa
630.806.2000 x1515
Behalf
Of Kevin Simon
Kevin
Behalf Of
Manasa Reddy
help out...
Manasa
630.806.2000 x1515
Behalf
Of to.crds
occasional cleanup.
one, one at a time?
Thanks in advance,
Calvin
