Receipt of Purchase Orders with Zero Cost
In Vantage 8 you can customize the goods inwards screen to warn or stop
anyone form booking in zero value PO's.
Maybe a message telling the goods inwards user to contact the Purchasing
department.
Gary Parfrey
Of Alan Jensen
Sent: 14 December 2006 15:18
Subject: RE: [Vantage] Receipt of Purchase Orders with Zero Cost
We have this same problem but the only way we have fixed it is put the
price
field on our open PO report. This way we are constantly watching for it.
We
also had hopped that by not approving it we would not be able to receive
either. Would make sense that you can't receive a PO until it has been
approved. A lot of good the approval process is if you can just receive
items when something is not approved.
Hope to hear good solution to this problem we could use the help also.
Alan
_____
Behalf Of
surealloydan
Sent: Thursday, December 14, 2006 7:00 AM
Subject: [Vantage] Receipt of Purchase Orders with Zero Cost
Hello,
Occasionally, we send out purchase orders to suppliers that have a
zero entered for the unit price and a zero for total cost of the
PO. This occurs when the final cost will be determined by time and
material, and we have no idea what that final cost will be. This is
not a general practice, but it does happen from time to time. The
problem we are having is that we have not found a way within Vantage
(8.0) to keep these POs from being received within Vantage. We
tried to simply leave them unapproved, but they can still be
received. Do you know of a way or setting to block POs from being
received?
Thank you for any assistance.
Dan Murray
Purchasing Agent/I.T. Specialist
SAS Global Corporation
tel: (248) 414-4470
tel: (586) 510-3244 direct
fax: (248) 414-4490
danm@sasglobalcorp. <mailto:danm%40sasglobalcorp.com> com
Hello,
received?
Dan Murray
tel: (248) 414-4470
fax: (248) 414-4490
danm@...
We have this same problem but the only way we have fixed it is put the price
field on our open PO report. This way we are constantly watching for it. We
Alan
_____
surealloydan
Hello,
received?
Dan Murray
tel: (248) 414-4470
fax: (248) 414-4490
I'm on 6 but you may be able to do something similar in 8. I have a BAM
on my receipt table so when something comes in for an unapproved PO, I
display a message saying not to receive the goods. You may be able to
set one up to not receive the goods if the cost is zero.
Description: This program checks for receipt of unapproved POs.
Created By:
Butch Menge
Revision History:
12/11/04 Initial revision
Vantage 6.1
{ud/GlbAlert.i &TableName = "RcvHead"}
FIND POHeader WHERE POHeader.PONum = RcvHead.PONum no-lock.
IF POHeader.ApprovalStatus <> "A" THEN DO:
Message "Do not receive this order because the PO is not
approved! Contact Purchasing ASAP!"
View-as alert-box information buttons ok.
END.
Return "Cancel Send":U.
Return.
Butch
Of Alan Jensen
Sent: Thursday, December 14, 2006 7:18 AM
price
We
Alan
_____
Behalf Of
surealloydan
Hello,
received?
Dan Murray
tel: (248) 414-4470
fax: (248) 414-4490
