Received Lines
Bartosz
I had the same problem before. I think what happens , and I confirmed this with tech support is that after you received and inspect a line you cant delete that record. One question: during the inspection did it fail the inspection? In that case, you could open the dmr that was created by that line and put it back on your suggestions and delete it after since it will be seen as no transactions were made for that line.
Im thinking, maybe did you try delete that PO line .. does vantage let you do it?
Lissette C.
--- In vantage@yahoogroups.com, Bartosz Niemczewski <bartoszniemczewski@...> wrote:
> Our shipping department received parts from outside process - 2 lines. They should receive only one line. Lines are already inspected and we are looking the way how to reduce number of pieces or remove one received line.
> Any ideas?
> Thanks.
Any ideas?
Thanks.
