Yeah we are using SQL. Most of the reports donÂ’t just read data but
actually compile data into tables first and then read it, and then clear the
table.
Daniel Laidig
too_much_hg
Sent: Friday, April 24, 2009 1:50 PM
Subject: [Vantage] Re: Record lock timeouts
Daniel,
We see something similar to this.
Why would they lock a record when the report is only reading the information
in the first place ?
Are you running SQL ?
Neil
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Daniel
Laidig" <daniellaidig@...> wrote:
Behalf Of
table.
Daniel Laidig
too_much_hg
Daniel,
Neil
>when
> We got this Record lock timeout error pretty frequently (twice a week)
> first moving to Vantage 8. During the record timeout, MES could stillno
> process transactions but no one in vantage could save or add any records,
> matter what table. They could access all records but just couldn't saveit
> them. Once the user clicks save, the vantage screen just turns white and
> looks like vantage crashes. But if we instructed them to wait 30 minutes,[mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> the record lock would clear and their record would save. Users were
> obviously getting very frustrated and vantage support was, of course no
> help. They had no idea why our records were being locked and just told us
> we had to deal with it. We did find that every time our records were
> locked, a user had run a big report, mostly where used report WITHOUT
> putting a filter partnumber so it was running where used for ALL 80K parts
> in our database! When we had a record lock timeout and cleared a report
> that had been running in the background for days, everything went back to
> normal. So every night, we clear stale sessions and reports that are
> running and have been forgotten about. We haven't had a record lock since
> then. Hope that helps.
> Daniel Laidig
Behalf Of
> too_much_hghow/when
> Sent: Thursday, April 23, 2009 4:20 PM
> Yes, we are at Patch 33.
> I am going to post another question about how to do maintenance on the
> database .... like nullfixer.r and any other tools I should run and
> to run them.<mailto:vantage%40yahoogroups.com> ,
> Maybe I will get some good tips from that.
> Neil
> "Steve_E" <vantage@> wrote:<mailto:vantage%40yahoogroups.com>
> > No, I worked with tech and progress to fix the locking problem.
> > Have you installed the latest and greatest progress patch?
> > Steve
> > -----Original Message-----
> > From: too_much_hg [mailto:neil_willet@]
> > Sent: April 23, 2009 10:52 AM
> > Subject: [Vantage] Re: Record lock timeoutsfor
> > Has anyone out there modified this (progress side) parameter on their
> system ?
> > What experience have you had after making this change ?
> > Is this something that I would want to change even tho I have SQL 2005
> the Database ? Since SQL defaults to 3min maybe I should set my Progress1
> value to 5min from the default 30min.
> > Trying to understand the implications of making this change.
> > Thanks,
> > Neil
> > --- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com, DD
> <ddavis4569@> wrote:
> > > I believe you are thinking about the SQL database lock value. It
> defaults to 3 minutes.
> > > The Progress Lock Timeout is 30 minutes but can be set to a minumun of
> minute.is
> > > Â
> > > Â
> > > Â
> > > Lock Timeout (-lkwtmo) seconds
> > > The wait time, in seconds.
> > > Use Lock Timeout (-lkwtmo) to specify a different wait time (in
> seconds). A Progress process
> > > encountering a locked resource waits for a limited time before
> continuing execution. If the
> > > resource is still locked, the process times out and the wait is
> canceled. This feature is called
> > > â€Å"lock wait timeout.â€ÂÂ
> > > The default wait time is 1800 seconds (30 minutes). The minimum value
> 60 seconds. If a uservalue
> > > specifies a value less than 60 seconds, Progress silently sets the
> at 60 seconds.should
> > > NOTE: The wait time is accurate to within one minute of the value
> specified.
> > > Lock timeout applies to interactive and batch clients.
> > > Lock timeout affects WAIT-FOR record locks, schema locks, and
> transaction commit locks.
> > > Lock timeout does not affect internal locks used inside the database
> manager, such as buffer
> > > locks.
> > > --- On Wed, 4/22/09, Nigel Kerley <nigel.kerley@> wrote:
> > > From: Nigel Kerley <nigel.kerley@>
> > > To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
> > > Date: Wednesday, April 22, 2009, 3:06 AM
> > > Hi Neil,
> > > My understanding is that the default Progress timeout is 3 minutes.
> > > So if you can't find any setting that changes it, that's what it
> be.wrote:
> > > Nigel.
> > > --- In vantage@yahoogroups .com, "too_much_hg" <neil_willet@ ...>
> > > >a
> > > > Hi Nigel,
> > > > Do you know what the default value in PET is ?
> > > > I don't have any setting in mine and I think I have had some record
> lock problems as well.
> > > > Thanks,
> > > > Neil
> > > > --- In vantage@yahoogroups .com, "Nigel Kerley" <nigel.kerley@ >
> wrote:
> > > > > Hi Ed,
> > > > > The default timeout is (I believe) 3 minutes, so it appears at
> though someone has already adjusted yours. You need to find out where the
> config was adjusted and change this setting - rather than "blindly" insert
> new setting.first
> > > > > The usual place to make this change is in the mfgsys.pf file
> (\\server\epicor\ mfgsys\server\ config). There may be an entry on the
> line like "-lkwtmo 1800". The figure is the number of seconds for thearguments"
> timeout.
> > > > > The only other place I can think of for this is in the database
> settings within PET. Go to Databases | MfgSys803 | Configurations |
> defaultConfiguratio n - then Properties and look in "Other server
> for "-lkwtmo 1800".[Non-text portions of this message have been removed]
> > > > > By any chance, did this timeout come from a Service Connect
> workflow? The timeouts for them can be set in the workflow itself.
> > > > > Nigel.
> > > > > --- In vantage@yahoogroups .com, "Ed Garbowski" <egarbowski@ >
> wrote:
> > > > > > We ran into a progress record lock problem this weekend that
> brought to light an excessive timeout that I'd like to adjust. The lock
> released after 30 minutes which should be reduced to 2 minutes or so. Can
> anyone tell me where the database timeout defaults can be adjusted?
> > > > > > Thanks,
> > > > > > Ed
