Reference queries can't be used in BAQ reports?
yes
This actually does not appear to be fixed @Olga. While it no longer throws an error, it also does not provide the data from the reference query to the report itself, even after adding the field in the query expression and the field list and adding a control bound to that field on the rdl and publishing it (just stating the obvious - yes I did all the things that should need to be done for it to show up and it comes up blank even though running the baq directly shows it is populated). Of course we are cloud so its impossible for me to inspect the actual data being generated in the ssrs database. 2024.1.10 and apparently that’s all the updates we get.
Fix was done long ago, so your version should contain it. Report is as separate bug or the same, with exact steps, what is not shown in the report.
Also I think you can ask support to inspect what is generated in the ssrs database.
