Referencing other tables - code snippets
Before doing his via vb code (that has to be maintained forever) go to data tools and attempt to add the tables you desire as foreign key views or subtables (of a foreign key views).
Doing this makes them visible to the customization environment (where as VB function added tables are not visible to the environment).
Example: Material Issue has an "IM" native dataview. You can add a JobHead FKV to the IM table.
Once JobHead is added as an FKV, you can add almost all other job related tables (JobProd, JobOper, JobOpDtl, JobMtl, etc.,) as SubTables to the FKV JobHead table.
You must define the parent/child column joins (typically always want to reference Company then, in this case, JobNum, etc.,).
It is not always possible to find a 'path' to get from the native tables to the one you wish to include in the app.
When that proves true, set up a Function (intended to return whatever related data from your non native table you require based upon passing the function valid input variables). Go to Object Explorer and find the data table you are interested in and the method you wish to use to access the table (typically SearchByID). Copy the sample code snippets into your function (adjusting them to suit your app & purpose) and also make not of the 3 assembly DLLs required.
Go to Assemblies and add the three referenced assemblies as custom assemblies. (Without this, your code won't work.)
...Like I said, TRY using the data tools and FKV's/SubTables first!
It is much cleaner.
Rob Brown
--- On Thu, 5/1/08, Kunal Ganguly <kunal_vantage@...> wrote:
Subject: [Vantage] referencing other tables - code snippets
To: "Vantage Yahoo Group" <vantage@yahoogroups.com>
Date: Thursday, May 1, 2008, 7:52 AM
I need to get some data from separate tables into a form. Unfortunately, in the form designer the tables that I need are not shown as a data source. Would it be possible for someone to post some production or simply working code which does this.
Kunal
____________ _________ _________ _________ _________ _________ _
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now. http://mobile. yahoo.com/ ;_ylt=Ahu06i62sR 8HDtDypao8Wcj9tA cJ
____________________________________________________________________________________
know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
Kunal
Version?
Form?
Desired tables?
> Thanks,
> Kunal
____________
My bad, that first e-mail was rather lacking in information!
Version: 8.03.404A
Form: Shipping & Receiving | Gen Ops | Customer Shipment Entry
Tables: OrderHed, Terms
Any generic examples not having anything to do with the above would be fine too.
-Kunal
----- Original Message ----
Sent: Thursday, May 1, 2008 6:55:13 AM
Subject: [Vantage] Re: referencing other tables - code snippets
Version?
Form?
Desired tables?
> Thanks,
> Kunal
____________
OK, Customization Tools Dialog, Tools menu, Data Tools.
Click New Custom View, Give a descriptive name for View Name like
OrdHedView. In the Parent View Name drop down, pick ShipHead. In
Column Name drop down pick OrderNum - Click Add button you should get
a foreign key view sucessful dialog box - click OK. Save you
Customization. Re open it and you should be able to use fields from
order header now on your form. The terms code and terms code
description are available in the view you added to the data tools.
Many times you can get data from other tables when there is a field
used in one of the native dataviews that is a key field to get data
from a different table. There are instances when you just cant get
there using Foreign Key Views or another view from a FKV. Then you
will have to get creative and start using list lookups. If you cant
find what you need using a list lookup then you will have to add
adapters, dataviews, etc.
I always try to start with the easy way first :o)
bw
> Version: 8.03.404A
be fine too.
> -Kunal
> From: bw2868bond <bwalker@...>
> Version?
> Form?
> Desired tables?
some
> > Thanks,
> > Kunal
> ____________
______________
Thank you very much! That will be a huge huge help for some other customizations I need to do as well :))
For some reason the custom form elements (tried both textbox and combo) I added for terms and freight are blank when i bring up some data on the customer shipment entry form. The Shipment entry form allows picking of a pack id, and the order number field below it shows up as blank, I wonder if this is why the terms and freight elements I created are blank.
Also, for future reference, would it be possible to share some custom code that deals with adapters and dataviews in the context of this discussion?
Kunal
Sent: Thursday, May 1, 2008 8:12:36 AM
bw
> Version: 8.03.404A
be fine too.
> -Kunal
> From: bw2868bond <bwalker@... >
> To: vantage@yahoogroups .com
> Version?
> Form?
> Desired tables?
some
> > Thanks,
> > Kunal
> ____________
____________ __
Ok, figured it out - if I use the ShipDtl table, the data displays normally. TYVM BW for your help.
I have quite a few more customizations remaining which I am pretty sure will require code since (I think) there will be no foreign key that I can use.
-Kunal
Sent: Thursday, May 1, 2008 9:18:56 AM
Subject: Re: [Vantage] Re: referencing other tables - code snippets
Kunal
bw
> Version: 8.03.404A
be fine too.
> -Kunal
> Version?
> Form?
> Desired tables?
some
> > Thanks,
> > Kunal
> ____________
____________ __
