Good Day:
RE:Refresh a dashboard Get a trigger to 'see' a field
Two programming questions:
1. On a dashboard, is there a way to create a program that will
"refresh" the Dashboard in the same way as the refresh button on the
toolbar, using vb.net.
I want to use an "event" to trigger the refresh.
2. How do you reference a dashboard's filtered textbox in vb.net. and
create an event for it . The Event Wizard only seems to show the "Custom
Controls" that a user has added. In my example, a textbox
"numQuoteHed.QuoteNum" was added as a filter on a dashboard tracker. I
want an event that triggers when the user leaves that textbox (loss
focus).
len.hartka@...
<blocked::blocked::mailto:len.hartka@...>
Leonard C. Hartka, IS Project Manager\ERP Specialist
Sun Automation Group
66 Loveton Circle
Sparks, Md. 21152
410-329-3560 ext. 120
410-329-3564 FAX
443-255-7192 Work Cell
len.hartka@...
www.Sunautomation.com <blocked::blocked::http://www.sunautomation.com/>
Celebrating
25 Years of Service
to the Corrugated Industry
This e-mail and any attachments may contain proprietary and/or confidential information. If you are not the intended recipient, please notify the sender immediately by reply e-mail or at 410-472-2900 and then delete the message without using, disseminating, or copying this message or any portion thereof. With e-mail communications you are urged to protect against viruses.
focus).
len.hartka@...
66 Loveton Circle
Sparks, Md. 21152
410-329-3564 FAX
len.hartka@...
Celebrating
25 Years of Service
