On Tue, Oct 13, 2015 at 9:39 AM, Rob Bucek rbucek@... [vantage] <vantage@yahoogroups.com> wrote:Â<div> <p>Ok, by no means am I an expert here, but this is what I usually do in this instance
Make sure you bring in your assembly references for UD08 (I usually bring in the contracts & the adapter cuz it really doesn’t hurt)
In your public class script (I do this here so I only have to do it once for the entire customization)
private EpiDataView edvUD08;
private EpiBaseAdapter oTrans_adapter;
In your InitializeCustomCode()
this.edvUD08 = ((EpiDataView)(this.oTrans.EpiDataViews["UD08"]));
In your Event
Ice.Adapters.UD08Adapter ud08Adapter = new Ice.Adapters.UD08Adapter(UD08Form);
Ud08Adapter.BOConnect();
string Key1 = edvUD08.dataView[edvUD08.Row]["Key1"].ToString();
bool MyUD = ud28Adapter.GetByID(Key1, "", "", "", "");
hope this helps
Rob Bucek
Production Control Manager
D&S Manufacturing
301 E. Main St. | PO Box 279
Black River Falls, WI 54615
715-284-5376 Ext. 311
Mobile: 715-896-3119
rbucek@...
www.dsmfg.com<http://www.dsmfg.com>
Sent: Tuesday, October 13, 2015 7:54 AM
Subject: [Vantage] Re: Refresh Doesn't Work on UD Tables
Am i over complicating this? here's what i have in C# right now. I get to Message 4 and then get an unhandled exception error: Object reference not set to an instance of an object.
private void baseToolbarsManager_ToolClick(object sender, Infragistics.Win.UltraWinToolbars.ToolClickEventArgs args)
MessageBox.Show("GotHere0");
if(args.Tool.Key.ToString() == "RefreshTool") // Action will only run when refresh button is clicked
MessageBox.Show("GotHere1");
EpiDataView edvUD08 = ((EpiDataView)(oTrans.EpiDataViews["UD08"]));
string key1 = (edvUD08.dataView[edvUD08.Row]["Key1"]).ToString(); //Find Key 1 Field and set to key1 var
MessageBox.Show("GotHere2");
UD08Adapter myUDAdapter = new UD08Adapter(((Session)oTrans.Session).ConnectionPool);
MessageBox.Show("GotHere3");
myUDAdapter.BOConnect();
MessageBox.Show("GotHere4");
bool myUD = myUDAdapter.GetByID(key1,"","","","");
MessageBox.Show("GotHere5");
myUDAdapter.Dispose();
MessageBox.Show("GotHere6");
</div> <div style="color:rgb(255,255,255);min-height:0px;"></div>
So I'm using some UD tables and the Refresh button doesn't work. I've called Epicor and they said it's still a problem in 10 so they don't anticipate a fix anytime soon. Anyone else run into this? If so what did you do to fix?
Bobby
Jose C Gomez
T: 904.469.1524 mobile
On Mon, Oct 12, 2015 at 8:37 AM, ralmon@... [vantage] <vantage@yahoogroups.com> wrote:Â<div> <p>Anyone have any ideas or suggestions on how to make this work in C#? </p><div><br></div><div>Thanks </div><div>Bobby</div><p></p> </div><span class="ygrps-yiv-849689384"> <div style="color:#fff;min-height:0;"></div>
Not sure if this helps any, but I usually find when I get the error: Object reference not set to an instance of an object, that the data I’m using has a null field or something else missing. It could be your code is ok, but your data is not good.
Just a thought.
Steve
Sent: Tuesday, October 13, 2015 8:54 AM
In your Event
hope this helps
Rob Bucek
D&S Manufacturing
rbucek@...
