Rejecting assemblies
Thanks for the input to date. The assembly was not called out as material,
we created a pull qty (thus removing the alert to build the assembly), and
then issued to the assembly. I want to reject one piece from the pull qty
but like I said I can't because it is saying I can not reject what was not
built. Why will it not allow me to reject an issued qty to an assembly. Yes,
I could do a reverse issue for the one piece and reject it against
inventory but that seems like a lot of work when I should just be able to
reject against the assembly. Any more input would be great. Thanks.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf
Of Paul H. Smith
Sent: Monday, May 22, 2006 9:39 AM
To: Vantage
Subject: [Vantage] Rejecting assemblies
Hello group
We have a part that was in stock and issued to the assembly I want to
reject the assembly but can not. Here are the details: We set up the
assembly with a pull qty of 21, then our material control dept issues the
assemblies (STK-ASM). The assemblies are not listed under material. So now I
go to reject one pcs by using the non-conformance, operation. I enter the
required information, then click enter. The following error is posted "the
non conformance qty can not be greater than the manufactured qty of zero".
Well I know we did not MFG any but we did issue 21 pcs to the assembly. We
are currently using vantage 6.0. Any help on this would be great. Thanks in
advance.
Paul H. Smith
Inventory Manager
Espey MFG.
233 Ballston Ave
Saratoga Springs, NY 12866
518-245-4358
Yahoo! Groups Links
Hello group
advance.
Paul H. Smith
Inventory Manager
Espey MFG.
233 Ballston Ave
518-245-4358
Paul:
Do you want to reject just the material? If so, you'll have to un-issue the material from the job in order to
reject it. If you have to reject the assembly due to the bad material - you'll have to run enough parts thru to be able to reject them, because the system is thinking you are rejecting the assembly now, not the material, which is why it gives you that message.
At least that's how is works for us on 6.1.
Hope that helps.
Julie
Mercury Minnesota Inc.
----- Original Message -----
To: Vantage
Sent: Monday, May 22, 2006 8:38 AM
Hello group
advance.
Paul H. Smith
Inventory Manager
Espey MFG.
233 Ballston Ave
518-245-4358
SPONSORED LINKS Manufacturing software Membership database software Database mortgage software
Pda database software Database management software Database marketing software
YAHOO! GROUPS LINKS
a.. Visit your group "vantage" on the web.
b.. To unsubscribe from this group, send an email to:
c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
Dear Paul,
We don't use assemblies, but I think what you want is the Materials
Management "Issues/Returns" transaction. This lets you process a
material return from an assembly. We use it for over-issues of
material to jobs.
Regards,
Ruth Joy
--- In vantage@yahoogroups.com, "Paul H. Smith" <psmith@...> wrote:
> Hello group
want to
issues the
So now I
enter the
posted "the
zero".
assembly. We
Thanks in
> advance.
> Paul H. Smith
> Inventory Manager
> Espey MFG.
> 233 Ballston Ave
> 518-245-4358
You don't have return the material to inventory you can create a
non-conformance from the material line... as long as it is called out on
the bill of material.
