Remove Demand Blank Title 64593
UnFirm MRP Jobs must be Firmed before the Engineer check box (among other things) becomes enabled for editing.
--- On Wed, 5/7/08, Tony Hughes <thughes281@...> wrote:
Subject: Re: [Vantage] Remove Demand
Date: Wednesday, May 7, 2008, 11:59 AM
Thank you Gary,
I tried unengineering the job, but if I open the MRP job in Job Entry, the Engineered check box is greyed out.
Tony
----- Original Message ----
To: vantage@yahoogroups .com
Sent: Wednesday, May 7, 2008 10:36:06 AM
Subject: RE: [Vantage] Remove Demand
Tony
Highlight the order link in Job Entry grid line and press delete. The
job may need to be unengineered.
Gary
Dot Net IT Limited, Reg No 4412519
From: vantage@yahoogroups .com [mailto:vantage@ yahoogroups .com] On Behalf
Of Tony Hughes
Sent: 07 May 2008 16:17
Subject: [Vantage] Remove Demand
I haven't seen this problem before, so not sure how to fix it.
User made an order, I guess (what they say) they entered a part that
didn't exist in part master, which then created the "make to order"
demand on that release, created an MRP job.
This is an error, the part is wrong, and the demand needs to be removed
and the MRP-created job deleted, the release line deleted and the whole
thing started over.
So, how do I delete the demand, so that I can delete the job, so that I
can delete the release so that I can delete the line?
I assume this has nothing to do with the actual "Demand" module, as we
don't license it, the demandheader, demanddetail tables are empty.
When I look at a job in Job Entry, what defines the records that are
showing in the Demand Summary tab?
if I see that the Demand Status is = 'voided' (because I 'closed' the
release), what do I do with the MRP-created job? It isn't Firm, so can I
just safely ignore it?
Do I just leave it as it is, with demand voided, everything is ok?
Thanks for any help or advice
____________ _________ _________ _________ _________ _________ _
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now.
http://mobile. yahoo.com/ ;_ylt=Ahu06i62sR 8HDtDypao8Wcj9tA cJ
know-it-all with Yahoo! Mobile. Try it now. http://mobile. yahoo.com/ ;_ylt=Ahu06i62sR 8HDtDypao8Wcj9tA cJ
____________________________________________________________________________________
know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
User made an order, I guess (what they say) they entered a part that didn't exist in part master, which then created the "make to order" demand on that release, created an MRP job.
This is an error, the part is wrong, and the demand needs to be removed and the MRP-created job deleted, the release line deleted and the whole thing started over.
So, how do I delete the demand, so that I can delete the job, so that I can delete the release so that I can delete the line?
I assume this has nothing to do with the actual "Demand" module, as we don't license it, the demandheader, demanddetail tables are empty.
When I look at a job in Job Entry, what defines the records that are showing in the Demand Summary tab?
if I see that the Demand Status is = 'voided' (because I 'closed' the release), what do I do with the MRP-created job? It isn't Firm, so can I just safely ignore it?
Tony
Gary
Of Tony Hughes
thing started over.
Thank you Gary,
Tony
Tony
Gary
From: vantage@yahoogroups .com [mailto:vantage@yahoogroups .com] On Behalf
Of Tony Hughes
thing started over.
Firm the job firs, delete the firm job once you have unlinked the demand
Gary
Of Tony Hughes
Sent: 07 May 2008 17:00
Thank you Gary,
Tony
From: Gary Parfrey <garyp@... <mailto:garyp%40dotnetit.co.uk>
Tony
Gary
Behalf
Of Tony Hughes
thing started over.
