Remove/Disable Context Menu Items
Ray,
If you're speaking of removing context items, such as being able to right
click in the Part Number field and choose Open With Part Tracker, I'm not
sure if you can remove them. However, I believe you can hide the existing
field, and replace with your own custom field, and I don't believe the
custom fields, even if it's pointing to the same datasource, has the context
menus with them.
Not the most ideal solution, but perhaps a solution none-the-less.
HTH,
Kevin Simon
zanniebelle
Sent: Sunday, March 20, 2011 11:35 AM
Subject: [Vantage] Re: Remove/Disable Context Menu Items
Thanks Dan for the reply.
I'm actually looking to remove/disable context menu items on a specific
sceen, not all screens. That's why I was looking for a solution in code
instead of using the framework option.
Ray
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , Dan
Godfrey <dgodfrey@...> wrote:
> Under System Management -> Utilities -> Context Menu Maintenance
Behalf Of zanniebelle
> Sent: Friday, March 18, 2011 12:01 PM
> Subject: [Vantage] Remove/Disable Context Menu Items
> Does anyone have an example of disabling or removing Context Menu items in
code via a customization?
> Thanks!
Does anyone have an example of disabling or removing Context Menu items in code via a customization?
Thanks!
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of zanniebelle
Thanks!
I'm actually looking to remove/disable context menu items on a specific sceen, not all screens. That's why I was looking for a solution in code instead of using the framework option.
Ray
> Thanks!
