Remove InfoZone BAQ arrow?
Hi, I can’t see how to remove this Info Zone search arrow from a dashboard column… anyone know? I’ve tried restarting several times.
Error is “Info Zone Search requires initial value on the host control.”
Zone BAQ field is clear in Extended Properties.
Thanks!
I think you are in the wrong table, you have OpMaster, not sure that’s the correct table for this BAQ.
If you look at the BAQ behind the Dashboard and identify the table the OpCode field is coming from, and bring that table up in Extended Properties Maintenance and you should see a BAQ ID in the Zone BAQ.
Bingo thanks! Was on JobOper table.
