Remove required field 8.0
The simplest solution to this is to create a Marketing Campaign called
'default' and then enter this in the company configuration. This way you
never need to enter it when created a new Sales Order but the field is
still available for use at a later date.
Hope this helps
--- In vantage@yahoogroups.com, "Joe Luster" <jluster@...> wrote:
> So I read here:
http://tech.groups.yahoo.com/group/vantage/message/52966
> how to make a field required. (Seems like a lot of work.) But how do I
> remove a required filed? I'm in the Sales Order Entry Form and I want
to
> remove marketing campaign as a required filed. There are no rules that
> show up in the Rules Wizard when I customize this form. Anyone have a
> clue?
> Joe Luster
> Network Administrator
> Cold Jet, LLC
> 513-831-3211 ext. 308
> 513-831-1209 FAX
> <http://www.coldjet.com>
So I read here: http://tech.groups.yahoo.com/group/vantage/message/52966
remove a required filed? I'm in the Sales Order Entry Form and I want to
clue?
Joe Luster
Cold Jet, LLC
513-831-1209 FAX
