The BL tester basically just lets you call the various methods on a given
Business Object directly. I'd give it a shot as it's very easy to do.
(Probably 5-10 minutes at the most if you've never used it before) Though
honestly, if the UI isn't letting you delete it, I tend to doubt going
straight to the BO would help.
On Sat, Jul 23, 2011 at 10:54 AM, cooner_55421 <cooner_55421@...>wrote:
> I saw this in the knowledge base:
> https://epicweb.epicor.com/ReportServer/Pages/ReportViewer.aspx?/ePortal/ABDetail&rs:Command=Render&rc:Toolbar=true&Card_ID=5185ESC&Answerbook=Vantage%2fVista+8.0+-+Suggested+Enhancemets
> If you have a corrupt dashboard, you should be able to use the File >
> Delete Dashboard Definition process, however, if you cannot delete it this
> way, you may be able to delete it using a tool called "BL Tester." This tool
> is available on the Vantage Download site. Unfortunately, it is not a
> supported tool, but a Tech Support analyst may be able to assist you in BL
> Tester basics. When using the BL Tester you need to open the dashboard
> business object.
> --- In vantage@yahoogroups.com, "jplehr" <jlehr@...> wrote:
> > Yep. You open it and should have the option to "Delete Dashboard
> Definition" but it is not available.
> > Can you explain further listing the contents of DashBdChunk and
> DashBdDef? What will this tell me?
> > Thanks.
> > --- In vantage@yahoogroups.com, "cooner_55421" <cooner_55421@> wrote:
> > > You open it...
> > > The file menu "Delete Dashboard Definition" is not there?
> > > I have not seen this.
> > > Just a guess.
> > > I might try listing the contents of DashBdChunk & DashBdDef tables.
> > > --- In vantage@yahoogroups.com, "jplehr" <jlehr@> wrote:
> > > > Vantage 8.03.409C
> > > > Have an where I created a dashboard and everything was good to go.
> But, when I logged out of Vantage and then back in I could not get the
> dashboard to open. I am speaking when I am in developer mode.
> > > > Here is what took place. Created my dashboard with everything to my
> likeing. Had to leave. Came back and opened the dashboard in developer mode.
> I could see my dashboard in the search list, however when I select it
> everything seems to be loading but my dashboard is not there. I can't delete
> it either because it doesn't give me the option to delete dashboard
> definitions.
> > > > I am trying to delete everything and start over. I am looking for
> another way to delete the dashboard. Any thoughts?
> > > > Jeff
*Waffqle Driggers*
*High End Dev, System Design, Profit Drinking
*:: 904.962.2887*
*:: waffqle@...*
*:: NO FAXES*
