Removing Wizard generated code in a customization
Some of the wizards and “helpers” in the form customization environment, don’t have a way to easily remove the auto generated code.
Is going into the Script Editor and slashing away, the only way to remove these, totally ignoring the “Do not delete 'Begin/End Wizard Added Object …” remarks?
And any pointers on what to look for when trying which code to gut?
I assume the comments like // ** Wizard Insert Location - Do not delete... need to be in the file, and are used by the code generating tools to locate where to insert code. This correct?
You can remove any code you want, just don’t touch those comments it will break the customization’s ability to insert wizard code.
So any actual code between those comments is fair game to remove, but don’t touch the comments itself.
And I can delete all the auto generated functions. For example, I added UD08 as a child table, and now want to remove it. Any function with UD08 in the name, like:
private void InitializeUD08Adapter(){...}
private void GetUD08Data(...){...}
private void GetNewUD08Record(){...}
private void baseToolbarsManager_ToolClickForUD08(...)){...}
private void AbcCodeForm_BeforeToolClickForUD08(...){...}
// etc ...
yeah anything you want as long as you keep the comments intact.
And what about stuff that doesn’t show in the code editor, like the following that can be seen in the Customization Maintenance:
I fear that leaving that might not cause any problems … Until I actually decide to add UD08 at a later date.
I dont think that leaving them will cause a problem as if re-adding functionality that would use them the editor wont add them if already there.
It is cleaner I guess to remove, but to be honest provided the script itself is clean (so it doesnt confuse someone that subsequently maintains it) then i wouldn’t worry about it as they are standard dlls.
Regarding the standard comments, one thing to be aware of is a long time ago they changed slightly, not obvious but enough to stop wizards working. Somthing to bear in mind if modifying stuff as part of an uplift (I think the change was in 10.0.something??)
