Reorder Resource Group Maintenance Resources
Is there any way to reorder the resources in a Resource group or do you have to delete the group and start over?
I didn’t think they were numbered apart from their designator. In our system the lowest numbered resource appears first. I can’t imagine that was due to careful population by the folks entering them, it has to be the default.
Worst case, you can delete the resources in the group and add the resources back in, but I think they will still be numbered by resource designator.
I’m thinking I wont be able to delete them as transactions have occurred against them.
@Gil_V is correct – the only way Resources are ordered is alphabetically. Deleting them and re-adding them in a different order won’t change their display order unless you change the resource ID/description.
