Repeat relative to qty of parts
Continuing...
My original request appeared in Digest 2365
In answer to Michael Podlin's questions...
We print from the Vantage menu
As to the RB-copies...
Thanks Mike Tonoyan for the suggestion yet...
The info I am printing is the group header for JobAsmbl.partnum
From what I can tell the RB-Copies only respond with info printed in the RECORD line.
How can I make the Group-bands print in a variable number?
Thanks for all comments
BW
____________________________________________________
From Digest #2365
Message: 7
Date: Mon, 28 Apr 2003 13:37:53 -0500
Subject: RE: RE: repeat relative to qty of parts
How and where do you print the RB report from? Outside of Vantage using
Report Builder? In Vantage from a menu? In Vantage from a VBForm? Simple
routine can take ProdQty and set the RB-COPIES to that and then print them.
Message: 8
Date: Mon, 28 Apr 2003 11:24:46 -0700
Subject: Re: RE: repeat relative to qty of parts
From RB Properties menu select Record Layout. At the lower left corner above the buttons there is an area for Copies.
Select Field and select the field you want to use for number of copies.
I hope this will work for you.
Mike Tonoyan / MIS Manager
All American Products Co.
1135 Aviation Place
San Fernando, CA 91340
USA
Tel.: 818-361-0059 Ext.: 246
Fax 818-898-2236
E-mail: miket@...
Web: www.allamericanproducts.com
----- Original Message -----
To: <vantage@yahoogroups.com>
Sent: Monday, April 28, 2003 11:03 AM
Subject: [Vantage] RE: repeat relative to qty of parts
> This request is a good one for all of you wizards out there.
> We are on Vantage 5.1
> I want to print tags for each part made.
> I have a RB report which links Jobhead, JobOper, JobAsmb, etc.
> If the the JobHead. ProdQty says 4
> I want to print 4 tags
> If it says 1
> I want to print 1 tag
> Any ideas?
> All suggestions appreciated.
> BW
If it says 1
Any ideas?
BW
Babette Welch
MIS Director
Argonics
1110 Wright
Marquette MI 49855
906.226.9747 ext 235
906.228.0951 fax
Sent: Monday, April 28, 2003 1:04 PM
If it says 1
Any ideas?
BW
Babette Welch
MIS Director
Argonics
1110 Wright
Marquette MI 49855
906.228.0951 fax
1135 Aviation Place
USA
Fax 818-898-2236
E-mail: miket@...
> If it says 1
> Any ideas?
> BW
> Babette Welch
> MIS Director
> Argonics
> 1110 Wright
> Marquette MI 49855
> 906.228.0951 fax
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have already linked your email address to a yahoo id to
enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto:
> (2) To search through old msg's goto: http://groups.yahoo.com/group/vantage/messages
> (3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/links
