Replacement of the 10.0 BPM ExecuteBase() function in 10.2?
Does anyone have a Replacement of the 10.0 BPM ExecuteBase() function in 10.2?
ExecuteBase never was a part of public BPM API and never was documented.
So, any use of it was not supported officially.
I removed this stuff in 10.0.700 (AFAIR). And there is no replacement for it.
Default method implementation is called automatically between pre- and post-processing directives.
I believe if you make the same bo call with bypassed facade it will basically execute the base sans BPM
Mighty be a method to get where you are trying to
However, it is not the replacement for ExecuteBase but it should work.
Bypassing facade disables MDs’ execution.
