Replacing Vantage Server
Jasper -
It should work just as it does for the print-server, in that it will
respond to the alias. Of course, this assumes you made the
registry-changes and can effectively map a drive to the alias-name. The
client-install asks for the name of the server so the client can
establish the connection to the server; if the server responds, the
client should be happy and not really care what the *real* name of the
server is.
Let us all know how it goes.
--Ari
Of Jasper Recto
Sent: Monday, March 10, 2008 11:12 AM
To: 'vantage@yahoogroups.com'
Subject: RE: RE: RE: [Vantage] Replacing Vantage Server
Ari,
Just started playing with the DNS alias on our printer server and it
works nicely.
However, I have a question about how it would work with Vantage. If I
mapped a drive to Vantage using the DNS alias,
doesn't the name of the computer play a part in the client installation.
As I recall, it ask for the computer name of the vantage server.
Would that be an issue?
Jasper
[mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ]On
Behalf Of Ari Footlik
Sent: Friday, March 07, 2008 3:48 PM
Subject: RE: RE: [Vantage] Replacing Vantage Server
Jasper, you could IF:
You rename the existing server and then create a DNS-alias with the old
name. Renaming the existing server will force a reboot, of course, so
you'd have to do it during a regular maintenance window. You would also
want to implement the registry-change before renaming the machine,
because the registry-change requires a restart of the "Server" service,
which will effectively do the same thing as a reboot, so you might as
well consolidate reboots...
I'd try playing around with DNS-aliases for something other than your
production Vantage server before implementing. Also - a PING test will
not suffice - a server will respond to an alias-PING as soon as the
alias (C-name) is created. The acid test is to try connecting to the
server by using its alias in a UNC path (or mapping a drive).
--Ari
<mailto:vantage%40yahoogroups.com> [mailto: vantage@yahoogroups.com
<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>]
On Behalf
Of Jasper Recto
Sent: Friday, March 07, 2008 1:15 PM
To: 'vantage@yahoogroups.com <mailto:%27vantage%40yahoogroups.com>
<mailto:%27vantage%40yahoogroups.com>'
Ari,
That's a very cleaver idea. If I wanted to do this for our new server,
can I start doing this even though the current clients are not pointed
to a DNS alias?
Jasper
[mailto: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
]On
Sent: Friday, March 07, 2008 2:05 PM
Subject: RE: [Vantage] Replacing Vantage Server
There is what perhaps may be a more desirable way to accomplish this
task:
Instead of using literal names for the servers, I have begun to use
DNS-aliases whenever possible, which will allow me in the future to swap
machines at will with very little thought given to how it will affect
users.
Basically, say we have a server named "SERVER-01.yourdomain.local"
Instead of mapping drive X: to \\server-01\epicor, I create a DNS-alias
called "VANTAGE.yourdomain.local" which points to "SERVER-01." Then the
drive is mapped to \\vantage\epicor
If I ever need to replace a server, I can simply re-create the DNS-alias
pointing to a different actual host-name, and nobody will ever know.
Best of all, both servers can remain online the entire time!
There is a registry tweak that needs to be implemented on the target
server(s) in order to allow responses to a DNS-alias (because Windows,
despite Active-Directory, is still a NetBIOS system). See this article:
http://support.microsoft.com/?kbid=281308
<http://support.microsoft.com/?kbid=281308>
<http://support.microsoft.com/?kbid=281308> >
< http://support.microsoft.com/?kbid=281308
<http://support.microsoft.com/?kbid=281308> >>
<http://support.microsoft.com/?kbid=281308> >> >
I've tried this successfully with Vantage 6.1 and 8.03.x BUT it doesn't
work with Windows Server 2003 x64 Edition, because the 64-bit edition
doesn't support use of the aliases.
Good luck - let me know if you need more detail.
--Ari Footlik
IT Manager
R. A. Zweig, Inc
Glenview, IL
On Behalf
Of Scott Litzau
Sent: Friday, March 07, 2008 12:48 PM
It has been awhile but I replaced our email server like that.
If I remember correctly, Before I took the server offline I made sure it
was
only a Member Server in the domain (your Vantage server should only be a
member server). After I took the server offline I then removed the
Server
from AD and all its DNS Entries. When I brought the new one online, I
made
it part of the domain as a member server, check AD to make sure that it
was,
and made sure DNS had the new entries for the new server. Never touched
a
client computer.
Scott Litzau, MCP
Olympus Flag & Banner
Information Systems Manager
scott.litzau@... <mailto:scott.litzau%40olympus-flag.com>
P: 414-365-9732
F: 414-355-1931
<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ]
On
Behalf Of
Jasper Recto
Sent: Friday, March 07, 2008 12:37 PM
To: Vantage Groups (E-mail)
Subject: [Vantage] Replacing Vantage Server
I wanted to see if anybody has every tried this.
I need to replace our Vantage server. What I would like to do is setup
this
server offline with the same computer name and IP address. Then I would
remove the old server and add this server to the network.
Since each client workstation installation is pointing to a mapped
drive,
would it still work without having to go to each workstation and
reinstall
the software?
Any ideas?
Jasper
have
and
<http://groups.yahoo.com/group/vantage/files/.> >
< http://groups.yahoo.com/group/vantage/files/.
<http://groups.yahoo.com/group/vantage/files/.> >>
<http://groups.yahoo.com/group/vantage/files/.> >> >
<http://groups.yahoo.com/group/vantage/files/.> >> >>
<http://groups.yahoo.com/group/vantage/messages> >
< http://groups.yahoo.com/group/vantage/messages
<http://groups.yahoo.com/group/vantage/messages> >>
<http://groups.yahoo.com/group/vantage/messages> >> >
<http://groups.yahoo.com/group/vantage/messages> >> >>
<http://groups.yahoo.com/group/vantage/links> >
< http://groups.yahoo.com/group/vantage/links
<http://groups.yahoo.com/group/vantage/links> >>
<http://groups.yahoo.com/group/vantage/links> >> >
<http://groups.yahoo.com/group/vantage/links> >> >>
Yahoo! Groups Links
I need to replace our Vantage server. What I would like to do is setup this server offline with the same computer name and IP address. Then I would remove the old server and add this server to the network.
Since each client workstation installation is pointing to a mapped drive, would it still work without having to go to each workstation and reinstall the software?
Any ideas?
Jasper
Trying it as we speak...I'll let ya know how it goes...
Darren Mann
IT Manager
Miller Products Co.
1015 N. Main St.
Osceola, IA 50213
Ph. 641-342-2103
Fax 641-342-3222
Of Jasper Recto
Any ideas?
Jasper
If I remember correctly, Before I took the server offline I made sure it was
member server). After I took the server offline I then removed the Server
from AD and all its DNS Entries. When I brought the new one online, I made
it part of the domain as a member server, check AD to make sure that it was,
and made sure DNS had the new entries for the new server. Never touched a
client computer.
Scott Litzau, MCP
scott.litzau@...
P: 414-365-9732
F: 414-355-1931
Jasper Recto
the software?
Any ideas?
Jasper
Yahoo! Groups Links
task:
users.
--Ari Footlik
IT Manager
R. A. Zweig, Inc
Glenview, IL
Of Scott Litzau
was
Server
made
was,
a
client computer.
Scott Litzau, MCP
P: 414-365-9732
F: 414-355-1931
Behalf Of
Jasper Recto
this
drive,
reinstall
the software?
Any ideas?
Jasper
have
and
Yahoo! Groups Links
Ari,
That's a very cleaver idea. If I wanted to do this for our new server, can I start doing this even though the current clients are not pointed to a DNS alias?
Jasper
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of Ari Footlik
task:
users.
http://support.microsoft.com/?kbid=281308<http://support.microsoft.com/?kbid=281308>
--Ari Footlik
IT Manager
R. A. Zweig, Inc
Glenview, IL
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf
Of Scott Litzau
was
Server
made
was,
a
client computer.
Scott Litzau, MCP
scott.litzau@...<mailto:scott.litzau%40olympus-flag.com> <mailto:scott.litzau%40olympus-flag.com>
P: 414-365-9732
F: 414-355-1931
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
[mailto: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On
Behalf Of
Jasper Recto
this
drive,
reinstall
the software?
Any ideas?
Jasper
have
and
http://groups.yahoo.com/group/vantage/files/.<http://groups.yahoo.com/group/vantage/files/.>
< http://groups.yahoo.com/group/vantage/files/.<http://groups.yahoo.com/group/vantage/files/.>>
http://groups.yahoo.com/group/vantage/messages<http://groups.yahoo.com/group/vantage/messages>
< http://groups.yahoo.com/group/vantage/messages<http://groups.yahoo.com/group/vantage/messages>>
http://groups.yahoo.com/group/vantage/links<http://groups.yahoo.com/group/vantage/links>
< http://groups.yahoo.com/group/vantage/links<http://groups.yahoo.com/group/vantage/links>>
Yahoo! Groups Links
--Ari
Of Jasper Recto
Ari,
to a DNS alias?
Jasper
task:
users.
--Ari Footlik
IT Manager
R. A. Zweig, Inc
Glenview, IL
On Behalf
Of Scott Litzau
was
Server
made
was,
a
client computer.
Scott Litzau, MCP
P: 414-365-9732
F: 414-355-1931
On
Behalf Of
Jasper Recto
this
drive,
reinstall
the software?
Any ideas?
Jasper
have
and
Yahoo! Groups Links
Ari,
Just started playing with the DNS alias on our printer server and it works nicely.
However, I have a question about how it would work with Vantage. If I mapped a drive to Vantage using the DNS alias,
doesn't the name of the computer play a part in the client installation. As I recall, it ask for the computer name of the vantage server.
Jasper
--Ari
Of Jasper Recto
To: 'vantage@yahoogroups.com<mailto:%27vantage%40yahoogroups.com>'
Ari,
to a DNS alias?
Jasper
[mailto: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ]On
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
task:
users.
< http://support.microsoft.com/?kbid=281308<http://support.microsoft.com/?kbid=281308>>
< http://support.microsoft.com/?kbid=281308<http://support.microsoft.com/?kbid=281308>> >
--Ari Footlik
IT Manager
R. A. Zweig, Inc
Glenview, IL
On Behalf
Of Scott Litzau
was
Server
made
was,
a
client computer.
Scott Litzau, MCP
P: 414-365-9732
F: 414-355-1931
On
Behalf Of
Jasper Recto
this
drive,
reinstall
the software?
Any ideas?
Jasper
have
and
< http://groups.yahoo.com/group/vantage/files/.<http://groups.yahoo.com/group/vantage/files/.>> >
< http://groups.yahoo.com/group/vantage/files/.<http://groups.yahoo.com/group/vantage/files/.>> >>
< http://groups.yahoo.com/group/vantage/messages<http://groups.yahoo.com/group/vantage/messages>> >
< http://groups.yahoo.com/group/vantage/messages<http://groups.yahoo.com/group/vantage/messages>> >>
< http://groups.yahoo.com/group/vantage/links<http://groups.yahoo.com/group/vantage/links>> >
< http://groups.yahoo.com/group/vantage/links<http://groups.yahoo.com/group/vantage/links>> >>
Yahoo! Groups Links
