Not entirely true. You can set up the Generic Text printer in
Windows and specify that it prints to file. You may get a
few control characters in the output but it can be cleaned up.
> Here is the best you can do with RB. Using the report builder program go to
> the EXPORT option under the file menu. You can then print the report to a
> text file which Word can handle. Your users will NOT be able to print to a
> text file using the custom reports options in Vantage. Only those users
> with the report builder program can EXPORT to a text file.
> Shirley Graver
> Systems Administrator
> Rubber Associates Inc.
> Cleveland, Akron
> We no longer allow attachments to files. To access/share Report Files, please go to the following link: http://www.egroups.com/files/vantage/
> (Note: If this link does not work for you the first time you try it, go to www.egroups.com, login and be sure to save your password, choose My Groups, choose Vantage, then choose Files. If you save the password, the link above will work the next time you try it.)
