Todd,
Great question!
In this case, the user ran a report that had been last modified connected to
the test database on a second partition of his hard drive. The laptop is
setup with a multi/boot setup. The first partition connects to the network,
the second partition is for local test database use when the user is writing
reports at home.
When the user launched the report from the live networked partition of the
hard drive, the report was still connecting to the test database on the
second partition of his laptop, but at first he wasn't aware of that, and
some time was wasted trying to figure out why changing particular numbers in
vantage wasn't changing the numbers on the report.
I recommended to him the solution that would make absolutely sure that when
he was logging into the live networked partition of his laptop, he would not
be able to connect to the database on his local drive. The liability of
running a test report and thinking it is live report could potentially be
significant.
Because he connects to the stand-alone test database partition with a local
administrator password that has no network rights, all I had to do is login
as local administrator and on his 'live' partion, and set the permissions on
the database directory so that his network login wouldn't be able to see the
vantage/db directory.
At the time, I was not aware of the "Always prompt for new connection"
option, but because of the number of reports the user runs from
reportbuilder that do have correct connection info, not having to type in
connection parameters every time is definitely a time saver. Plus if the
checkbox gets inadvertantly checked off, there is the liability of the user
unknowingly running bogus reports.
-Thaddeus
Sent: Thursday, January 10, 2002 2:14 PM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] Report Builder/Database Connection
Maybe I am misunderstaning the issue but couldn't you copy the report to
another PRL and in the process change the database connection for the "new"
report. Then copy the report back to the original PRL and NOT change the
new settings (either overwrite or give new name). This shuffle allows you
to change the connection.
-Todd C.
Sent: Thursday, January 10, 2002 4:10 PM
I know this one was posted a while back, but yesterday my boss was having
the same trouble. Here's the report I wrote to my boss regarding the issue.
We went with solution 1B, and it worked just fine.
REPORT BUILDER PROBLEM
Problem:
A report builder report created on the users laptop against the local test
vantage database still connects to the test vantage database when the user
logs on to the network, and is running the report builder executable from
the live database. Furthermore, a report builder report created that
references the live database, when opened up on the test server, using the
report builder executable in the test server installation, still connects to
the live database.
Reason:
Report builder does not allow a user to disconnect the master database table
in the report,
Once report builder initializes the report, and the connects to the database
path stored in the report, its to late to change the path.
Solution:
1. Force an error, so that Report Builder will fail to connect to the
database path stored within the report, and will prompt the user for the
correct database path. There are three way's I'm aware of to do this.
a. Place the test database on a completely standalone test server. A report
transferred from the live side to test side, and vice versus, will not
connect to the database path if the path does not exist
b. (My Recommendation) Separate NT logins. One login will have no access to
the live database directory, at least read-only rights to the test database.
One login will have no access to the test database directory, and at least
read-only access to the live database.
c. Open the PRL file in a hex editor, and search and replace one database
path with the other. STRONG RISK OF CORRUPTING PRL FILE, so you must have a
backup.
2.Launch the offending report from the vantage menu structure of the
database that you wish to run the report against. The report's database
connection info will be overridden by vantage. Will not change the fact
that when running report from within report builder, the report is
referencing the original database it was created for.
3.Launch the offending report from a 4GL program, overriding the database
connection info similar to the way vantage does. Same drawbacks apply, and
will require programming time.
Sent: Thursday, December 20, 2001 10:08 AM
YEAH!!! It's amazing what walking away and going to lunch can do!!! Your
comment about the Service Name didn't mean anything when I first read it. I
didn't realize that that field could change! (So much to learn about this
system!!) Anyway.....I changed it to what I hoped it would be and BINGO!!!
Thanks all!!!!!!
Tricia
Always" for the DB connection. This will make it pop up the DB connection
form every time you open a report. You can put an alternate DB connection
in the "Service Name" field at that point.<<<<
<http://docs.yahoo.com/info/terms/>
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://rd.yahoo.com/M=216105.1806326.3318126.1261774/D=egroupweb/S=17050071
83:HM/A=915130/R=0/O=1/I=brandr-lrec/postholidaygroup/*http://shopping.yahoo
.com/domain?d=holiday&cf=posthol01>
<http://us.adserver.yahoo.com/l?M=216105.1806326.3318126.1261774/D=egroupmai
l/S=1705007183:HM/A=915130/rand=872674843>
Great question!
reports at home.
significant.
-Thaddeus
-Todd C.
Problem:
the live database.
Reason:
in the report,
Solution:
backup.
Thanks all!!!!!!
Tricia
>>>>In Report Builder, try going into Options -> Preferences and check"Prompt
ADVERTISEMENT
