Report Builder Joins
Although I have not worked on any reports regarding the memo table, I
will agree with Sarah that using MS Access to handle difficult
reports has been very helpful to us. When the data is difficult to
report on or you require large amounts of groupings and calculations
I prefer to bring the data into Access using a Make Table Query.
Once the data is in my Access Tables, I can massage it in a variety
of ways to get the results I want, including changing data type. The
make table queries don't take that long to run (from a few seconds to
around 45 seconds depending on table size), and once the data is in
Access the reports generated off it run almost instantly. This
method works really well if the info on the report is only needed to
be updated daily and there are a lot of people who want to look at
the data, it's a lot better than a bunch of people waiting for a
Crystal Web report or a Report Builder Report. I still use those
tools for simpler reports, definately. But I've really been
utilizing Access more and more for the tougher projects.
My 2 cents,
Brian Stenglein
Clow Stamping Co.
--- In vantage@y..., sarah.vareschi@n... wrote:
> We also use memos quite a bit, and I totally agree that when
reporting, it
> is very cumbersome and slow to run, using report builder. I have
created
> some reports using ODBC and MSAccess, which work well and run fairly
> quickly. If it is available, you may want to try it...
Could someone help me out with this:
I have a hardware list created from Bill of Materials and from there
a Hardware List, etc. On this List, I want to add if needs
Purchased, Warehouse, and Bin.
I have it working except it gives multiple lines. If I take bin off,
a few extra lines are gone. This happens with the other 2 as well.
All 3 add extra lines and no 1 join takes the extra lines off at
once. This is what I did (by the way, there are 2 companies so I
need to filter each join by company):
Master: Job
Joins: Job to Job Mtl by JobNum
JobMtl to Pary by PartNum
(These 2 are fine to make the report function in general)
Now there is:
JobMtl to QuoteMtl by Co.
by PartNum (to get BuyIt)
Part to PartWhse by Co.
by PartNum (to get Warehouse)
Part to PlantWhse by Co.
by PartNum (to get Primary Bin)
Does anybody have a clue what I am trying to do or what I need to do.
Any ideas would be appreciated.
Thanks.
Hi everyone,
Can someome please help me with a RB join for the Memo Test Files. I'm
doing a Quote Follow Up Report for my salespeople and I want to print
specific memos for specific quotes. I am currently getting all memo
text printed with every quote on the report.
Janet Memmelaar
Vice-President Information Systems
Metal Cutting Corporation
973-239-1100 x 28
When I've joined to memos I've had to join on company only then filter for
key matches. Runs slow but works. I could not join with a key due to type
mismatch so filtering was the only way.
-Todd C.
Sent: Tuesday, July 09, 2002 9:26 AM
Subject: [Vantage] Report Builder Joins
Hi everyone,
Janet Memmelaar
973-239-1100 x 28
Yahoo! Groups Sponsor
<http://rd.yahoo.com/M=229641.2166546.3626727.1829184/D=egroupweb/S=17050071
83:HM/A=1142327/R=0/*http://promo.yahoo.com/debtscape/>
I've had success in joining memos by using calculated fields to make the
join. It does get hinky though because sometimes it works better converting
the actual field to the MEMO field format. It seems to work best if you
make the Memo file the master file and "PULL" the other records to the memo
record. Also I've used conditional printing to tune a report to the way I
want it
Shirley
Sent: Tuesday, July 09, 2002 10:57 AM
To: 'vantage@yahoogroups.com'
Subject: RE: [Vantage] Report Builder Joins
type
-Todd C.
Hi everyone,
Janet Memmelaar
973-239-1100 x 28
have
You can not join between the Quote Head table and Memos because the Quote
Number is a numeric field and even if you convert it with a calculated field
to character field report builder will not list is as a field you can use to
do a join. So regarding quotes you will have to filer for memos which means
you can get create a report if it's only filter for or list a single quote.
I hope someone can prove me wrong on this.
Patrick
Hi everyone,
Janet Memmelaar
973-239-1100 x 28
Patrick is certainly correct, I tried it both ways, and it doesnt fly. I
did have an off thought on how you could "possibly" make a direct link to
memo's. It would mean combining some other tools that we've talked about,
and using up one of the limited number of VB form fields. You could have
the quote number entered into an available character field in VB form's
either by hand, (high likelyhood of keying error) or by one of the automatic
VB field entry techniques we've talked about on list. If you were
consistant in doing this you could then "maybe" get a link. I havent tried
it though.
Shirley
Sent: Tuesday, July 09, 2002 12:40 PM
field
to
means
quote.
Patrick
Hi everyone,
Janet Memmelaar
973-239-1100 x 28
have
ADVERTISEMENT
There is a good way to do it, but you would need to submit it to Epicor as
an enhancement request.
On Memo records where Memo.Key1 is numeric (or for certain
Memo.RelatedToFile records) store the Key1 data in an additional INTEGER
field. This could easily be done in the write triggers for Memo.
Then you could do a nice simple effecient report builder join like:
QuoteHed.Company -> Memo.Company
"QUOTEHED" -> Memo.RelatedToFile
QuoteHed.QuoteNum -> Memo.IntegerKey1
-Wayne
Really a good Idea Wayne, 'cept by the time such an enhancement gets in,
it'll be Vantage 15, and I'll be sleeping next to Henny Youngman. (old time
comedian, "Take my program, PLEASE")
Shirley
Sent: Tuesday, July 09, 2002 1:30 PM
about,
-Wayne
I think I spot a CYNIC ...
Shirley
about,
-Wayne
Todd I resent that, I AM NOT A NETWORK CARD. Besides I only use 3Com
Shirley
Sent: Tuesday, July 09, 2002 2:09 PM
time
Shirley
to
about,
as
-Wayne
and
have
I'M SORRY. I BELIEVE I HAVE DETECTED SOME LEVITY IN THIS THREAD.
PLEASE CEASE AND DESIST AT ONCE.
THANK YOU.
GOD
----- Original Message -----
Sent: Tuesday, July 09, 2002 2:35 PM
Shirley
OK,
This is now a serious thread again. :"[
Since I only have to do it "This ONCE"
Shirley
Sent: Tuesday, July 09, 2002 2:51 PM
Subject: Re: [Vantage] Report Builder Joins
THANK YOU.
GOD
Shirley
You can accomplish this by doing the following join:
Create calculated field that turns the quotehed.quotenum to a trimmed text
string and then adding a filter of where the calculated field is equal to
memo.key1.
Tim
Sent: Tuesday, July 09, 2002 12:30 PM
-Wayne
Tim,
I tried a calculated field Called MyQuoteNum
Substring(QuoteNum,">>>>>>")
Also
TRIM(SUBSTRING(QuoteNum,">>>>>>")
but when you create a calculated field converting a numeric field to a
character string the field will not list when creating a join.
My master table is QuoteHead then I'm joining to MEMO like you suggested.
What exactly did your Calculated field look like?
Patrick
Sent: Tuesday, July 09, 2002 2:38 PM
memo.key1.
Tim
-Wayne
Tim,
My mistake you were filtering not trying to join.
Patrick
Sent: Tuesday, July 09, 2002 2:55 PM
Tim,
Also
Patrick
memo.key1.
Tim
-Wayne
>memo.key1.
That's the only way to do it currently.
Problem is, the performance gets worse EXPONENTIALLY as your file sizes
grow! This is true for all the files with integer IDs if you try to join
to Memo. If you join that way, then for each item in the main file it has
to go through *every* memo item related to that file. If you have 10,000
POHeader and 15,000 Memo records for POs, then report builder goes through
150,000,000 Memo records to run the report (which takes forever and a day
at that point!) If you can filter it down just on things in the header
file it's not so bad, but still a really slow report in most cases.
I suspect that Epicor (like many other software companies) does not have
any test databases in-house that are anywhere near as large as their
customers'. Many of the tech support documents refer to Dalton Mfg in the
regular (little tiny) training DB; so there's a good chance much of the
Epicor staff doesn't have a very good idea of real world DB
performance. Not trying to slam you guys Tim! Just an honest concern that
I know exists in many big software packages.
-Wayne Cox
Twenty Three -- Information Technology Consulting
828-685-2338
I agree with Wayne. The memo fields are a great place to store information,
but it is extremely difficult to design and run reports. Currently, we use
a memo reports to see the status on all open AR invoices, but it takes over
2 hours to run (and growing). I am not able to make a report work for
orders or POs (other than one at a time) which would be very useful to
Circuit Check. Online documentation (memos) are great, but it doesn't work
well for managers to get an overall picture of what is happening in their
department. It is difficult for me to push users to document issues in
memos when I can't write a reports to extract the information.
Making the memo table easier to write reports against would make the users
use the system to keep track of their area of expertise. Fixing this issue
would be HUGE for us.
Alex Neutgens
Controller
Circuit Check Inc.
Phone: 763.694.4110
Fax: 763.694.4151
Sent: Tuesday, July 09, 2002 3:04 PM
>memo.key1.
-Wayne Cox
828-685-2338
We also use memos quite a bit, and I totally agree that when reporting, it
is very cumbersome and slow to run, using report builder. I have created
So you can join a numeric and character field with MSACCESS which we cannot
in Report Builder?
From: sarah.vareschi@... [mailto:sarah.vareschi@...]
Sent: Tuesday, July 09, 2002 3:32 PM
