Report Builder - Multi Database Question
We are using Report Builder to generate a report which pulls data from
the Vantage database as well as a secondary "Tooling" database
(Progress). This works fine when run in the native Report Builder
format. When we place the report on the Vantage menu however we get an
error indicating that the "Tooling" database can not be found. The
"Tooling" database has a different logical name and service number. When
run in Report Builder that is preserved and runs without issue. When run
within Vantage the error results display a database connection box which
contains the regular Vantage database settings. When I override those
the report then runs.
Can I set the parameters in the Vantage.vtg file to include the
secondary "Tooling" database? If so what is the syntax and required
statements.
Thanks.
Keith
This e-mail and any attachments may contain confidential and
privileged information. If you are not the intended recipient,
please notify the sender immediately by return e-mail, delete this
e-mail and destroy any copies. Any dissemination or use of this
information by a person other than the intended recipient is
unauthorized and may be illegal.
