Report Builder / One Record Showing
Sorry Gary...new user to Report Builder. I am struggling with
Grouping and Sorting. If I move the data fields to the record
section then I get multiple entries of the same record?
--- In vantage@yahoogroups.com, "Gary Parfrey" <garyp@...> wrote:
> If you do that you will only show the last record (footer) or the
first
> record (header) in that group
> You need to move your data fields in the OrderRel Group section or
into
> the detail section, then you will see all the records appear!
> Gary Parfrey | Consultant | Dot Net IT Limited, 108 Waterfall
Lane, B64
> 6RE | Mob:07765 234934 | Email:Garyp@...
> This e-mail and any files transmitted with it are confidential and
are
> intended solely for the use of the intended recipient(s). If you
are not
> the intended recipient, you must not copy, distribute or take any
action
> based on this communication. If you have received this
communication in
> error please contact Garyp@... <mailto:Garyp@...>
> and delete this communication and any copies of it. Any views or
> opinions presented are soley of those of the author and do not
> necessarily represent those of Dot Net IT Limited.
> Dot Net IT Limited, Reg No 4412519
Behalf
> Of ctultra_met
> Sent: 11 May 2007 15:59
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Report Builder / One Record Showing
> all my fields are in the GF-ReqDate
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
> "Gary Parfrey" <garyp@> wrote:
> > Is your data fields in the group section or in the detail
> section. They
> > will need to be in the detail section
> > Gary Parfrey
> > From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> [mailto:vantage@yahoogroups.com <mailto:vantage%
40yahoogroups.com> ] On
> Behalf
> > Of ctultra_met
> > Sent: 11 May 2007 15:29
> > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > I am grouping by OrderRel.Reqdate
> > and Sorting by OrderRel.Reqdate, OrderRel.OrderNum,
> > OrderRel.OrderLine, OrderRel.OrderRelNum
> > still not working?
> > I am filtering by OpenRelease=yes and then OrderRel.Reqdate and
it
> > is not listing the correct release number either?
> > "Todd Caughey" <caugheyt@> wrote:
> > > What does your sorting and grouping look like? Is
> > Order/line/release below date?
> > > Sort order should maybe be something like:
> > > ReqDate
> > > Order
> > > Line
> > > Rel
> > > Then report either at the record level or do the grouping and
> > report at group footer for Rel.
> > > -Todd C.
> > > -----Original Message-----
40yahoogroups.com>
40yahoogroups.com>
> <mailto:vantage%
> 40yahoogroups.com> ]On
> > Behalf Of ctultra_met
> > > Sent: Friday, May 11, 2007 8:33 AM
> > > Subject: [Vantage] Report Builder / One Record Showing
> > > I am running a Scheduled Shipments report grouped by Order
> Release
> > > ReqDate but it only show one record per date. How do I get it
to
> > show
> > > multiple records for the same date?
I am running a Scheduled Shipments report grouped by Order Release
ReqDate but it only show one record per date. How do I get it to show
What does your sorting and grouping look like? Is Order/line/release below date?
ReqDate
Order
Line
Rel
Then report either at the record level or do the grouping and report at group footer for Rel.
-Todd C.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of ctultra_met
still not working?
I am filtering by OpenRelease=yes and then OrderRel.Reqdate and it
> ReqDate
> Order
> Line
> Rel
> -Todd C.
show
Is your data fields in the group section or in the detail section. They
Gary Parfrey
Of ctultra_met
still not working?
> ReqDate
> Order
> Line
> Rel
> -Todd C.
[mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ]On
show
section. They
> Gary Parfrey
Behalf
> Of ctultra_met
> still not working?
> > ReqDate
> > Order
> > Line
> > Rel
> > -Todd C.
Release
> show
If you do that you will only show the last record (footer) or the first
You need to move your data fields in the OrderRel Group section or into
Gary Parfrey | Consultant | Dot Net IT Limited, 108 Waterfall Lane, B64
This e-mail and any files transmitted with it are confidential and are
intended solely for the use of the intended recipient(s). If you are not
the intended recipient, you must not copy, distribute or take any action
based on this communication. If you have received this communication in
Of ctultra_met
section. They
> Gary Parfrey
Behalf
> Of ctultra_met
> still not working?
> > ReqDate
> > Order
> > Line
> > Rel
> > -Todd C.
<mailto:vantage%
Release
> show
