Report Builder- opposite of PREVIOUS(field) is?
One trick that I use is a counter. Create a counter for each line. If you are using groups, make sure it resets when it needs to. Make sure the counter does a prepass first than you can use an X +1 ideology to pick the next line.
Jasper
Sent: Wednesday, September 14, 2005 5:41 PM
Subject: RE: [Vantage] Report Builder- opposite of PREVIOUS(field) is
I found a work-around...change a sort to Descending Order (water cooler
talk goes a long way)
Thanks for your reply!
Of pjw@...
Sent: Wednesday, September 14, 2005 3:06 PM
There is no NEXT() command.
Of
Carol Engen
Sent: Wednesday, September 14, 2005 3:04 PM
Subject: [Vantage] Report Builder- opposite of PREVIOUS(field) is ???
The PREVIOUS(field) works, however, I am not finding a NEXT(field) in
the
canned formulas. Am I missing something?
(I am working with the VendPart, VendPBrk tables to get a range on the
quantity. The table only provides the minimum...the maximum would be at
the
next level.)
Thank you,
Carol Engen
Winona Lighting
Phone: 507-454-5113, Ext 314
Fax: 507-454-4806
e-mail: cengen@... <mailto:cengen@...>
Yahoo! Groups Links
the canned formulas. Am I missing something?
the next level.)
Thank you,
Carol Engen
Winona Lighting
Fax: 507-454-4806
Carol Engen
The PREVIOUS(field) works, however, I am not finding a NEXT(field) in the
quantity. The table only provides the minimum...the maximum would be at the
next level.)
Thank you,
Carol Engen
Winona Lighting
Fax: 507-454-4806
------------------------ Yahoo! Groups Sponsor --------------------~--> Fair
play? Video games influencing politics. Click and talk back!
http://us.click.yahoo.com/T8sf5C/tzNLAA/TtwFAA/PhFolB/TM
Yahoo! Groups Links
Of pjw@...
Of
Carol Engen
the
the
next level.)
Thank you,
Carol Engen
Winona Lighting
Fax: 507-454-4806
I think you can sort/group on an alias of the same table linked by the previous key values and then use the "regular" table as a "look ahead" or next version. This might be tricky though (depending on how smart RB is) if the sorting/grouping is not the same as the primary index you are linking on. If I recall correctly I did this once upon a time to "peek ahead" and anticipate a grouping change in order to condition some band lines.
-Todd C.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of Carol Engen
the next level.)
Thank you,
Carol Engen
Winona Lighting
Fax: 507-454-4806
_____
YAHOO! GROUPS LINKS
* Visit your group " vantage <http://groups.yahoo.com/group/vantage> " on the web.
vantage-unsubscribe@yahoogroups.com <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
_____
